Hi all,
I finally got my hands on the japanese Rohirrim disc with Japanese audio. However, my Panasonic UHD player will hide all japanese audio & subs.
I managed to rip the bluray with the japanese audio, but I desperately want to rip the UHD, having paid for the disc pretty handsomely.
MakeMKV returns a fatal error after trying a couple times.
My keys are up to date, this one doesn't work yet. I hope I'm doing this right. Let me know if not. Thanks in advance.
War of the Rohirrim - JAPANESE UHD
- MKB20_v77_LOTR-_The_War_of_the_Rohirrim_022F.tgz
- (204.93 KiB) Downloaded 1094 times
Re: War of the Rohirrim - JAPANESE UHD
I would guess that your UHD drive has not enabled LibreDrive:aleksoctop wrote: ↑Tue Apr 29, 2025 8:35 amMakeMKV returns a fatal error after trying a couple times.
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at &n`Eq#xL=:6?/jLfE:213130306
DEBUG: Code 0 at ,;C0yAY_BiPuE-x/)c:121264395
DEBUG: Code 4 at ,;C0yAY_BiPuE-x/)c:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
SDF v097: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MOAN9582642
Could you zip-compress the AACS/MKB_RO.inf file from your physical UHD disk please, and then post it here? The copy of this file inside your TGZ dump file has been truncated to only 56 bytes, making it unusable. This is also about the only extra information that you can provide about this disk without first enabling LibreDrive.
Signore Penguin,
muchas gracias for your reply! I was able to follow a guide to flash my drive to use LibreDrive and here's a new tgz dump along with the requested MKB_RO.inf file zipped up separately. Seems the size of the tgz is about the same as the first one, let me know if it's not useful please.
It ultimately fails to open the Japanese disc, of course.
Pretty ecstatic I was able to dump the 5.1 Japanese audio yesterday from the BD, seems i'm probably the only one who cares about this release.
- Rohirrim-JP-MKB_RO.zip
- (3.16 MiB) Downloaded 1083 times
- (203.41 KiB) Downloaded 1157 times
Can you delete that dump file now that you've flashed your drive, let MakeMKV recreate it, and upload a new copy please? It's the only way to help.
First, thanks for the complete MKB_RO.inf filealeksoctop wrote: ↑Tue Apr 29, 2025 6:19 pmmuchas gracias for your reply! I was able to follow a guide to flash my drive to use LibreDrive and here's a new tgz dump along with the requested MKB_RO.inf file zipped up separately. Seems the size of the tgz is about the same as the first one, let me know if it's not useful please.
Your new firmware doesn't appear to be LibreDrive-compatible either:
SDF v098: HL-DT-ST_BD-RE_BU40N_1.04_212005061142_MOAN9582642
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.04 MOAN9582642' at offset '1310720'
They really want to follow this guide.
viewtopic.php?f=16&t=19634
I missed that it wasn't LibreDrive enabled still. Without that, no dump will work, even sending it to the svq email address won't produce any results. A media key for this title does exist but without the other data it can't be used.
I did follow that guide and successfully flashed Archgon MD-8107-U3 (BU40N) with HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin.
It succeeded without error. I was then able to rip the US/international steelbook 4k and combine it with the japanese 5.1 audio i had ripped earlier off the BD (which by the way is in my humble opinion the definitive version of the film).
MakeMKV appears to say LibreDrive is enabled. Did I install the wrong firmware?
OS device name: /dev/rdisk4
Product: BD-RE BU40N
Revision: 1.04
Serial number: ...
Firmware date: 2120-05-06 11:42
Highest AACS version: 77
Firmware version: 1.04
Disc Information
Label: LOTR_THE_WAR_OF_THE_ROHIRRIM
Timestamp: 2025-01-25 16:21:08
Protection: AACS2.0/C v77
Data capacity: 81.55 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Revision: 1.04
Serial number: ...
Disc Information
Number of layers: 3
- (200.91 KiB) Downloaded 1112 times
It looks like a full entry for your disc was added to the keydb.
Epic, thank you so much! It's immeasurably better in Japanese.
