Furiosa a Mad Max Saga
Bentley0227
#1 Post by Bentley0227 » Tue Apr 29, 2025 4:52 am
I have searched the forum and chatgpt. I have downloaded keydb.cfg and put it in the directory folder and restarted and still nothing.
MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Saved AACS dump file as C:\Users\b3ntl/.MakeMKV/MKB20_v77_Furiosa-_A_Mad_Max_Saga_7079.tgz
Backing up disc into folder "E:/Video/backup/FURIOSA_A_MAD_MAX_SAGA"
Saved AACS dump file as C:\Users\b3ntl/.MakeMKV/MKB20_v77_FURIOSA_A_MAD_MAX_SAGA_7079.tgz
Backup failed
Not sure what's going on. It's a brand new copy.
Re: Furiosa a Mad Max Saga
#2 Post by dcoke22 » Tue Apr 29, 2025 1:20 pm
Read the Hashed Keys section of the UHD FAQ.
Also, please email your dump to svq@makemkv.com.
There's an alternative key mechanism that you could try called keydb.cfg (https://forum.makemkv.com/forum/viewtopic.php?p=162444#p162444)
Bentley0227
#3 Post by Bentley0227 » Tue Apr 29, 2025 2:33 pm
I emailed the files. Before I posted this, I tried the alternate keys, but they didn't work.
MrPenguin
#4 Post by MrPenguin » Tue Apr 29, 2025 3:44 pm
Bentley0227 wrote: Tue Apr 29, 2025 4:52 am I have downloaded keydb.cfg and put it in the directory folder and restarted and still nothing.
The KEYDB.cfg file is a "fallback database", which MakeMKV can use (if available) when it cannot find your disk in its own "hashed keys" database. But there's no guarantee that KEYDB.cfg will contain your disk either :).
Emailing your TGZ dump file to svq@makemkv.com allows MakeMKV to add your disk to the "hashed keys". Also providing your dump here potentially allows The Power That KEYDB to add your disk to KEYDB.cfg too.
