Dump Submitted Wargames
MKB20_v77_WARGAMES_E5EE submitted.
Re: Dump Submitted Wargames
Failing that, could you also make your TGZ dump file available here please, either as an attachment or by providing a download link? Then The Powers That KEYDB could examine it, and possibly even add your disk to KEYDB.
Here is the dump file. Hope it helps.
Here is a Link to the dumpfile MKB20_v77_WARGAMES_E5EE.tgz https://www.mediafire.com/file/dmsvit5m ... E.tgz/file. Hope it helps
Thanks for providing that. I would also recommend examining SamuriHL's KEYDB Helper tool, which helps MakeMKV integrate with the public KEYDB.miket wrote: Mon Apr 28, 2025 7:24 pm Here is a Link to the dumpfile MKB20_v77_WARGAMES_E5EE.tgz https://www.mediafire.com/file/dmsvit5m ... E.tgz/file. Hope it helps
keydb_helper
Thanks for the disc dump. The E5EE variant of Wargames has been added to the public keydb.
Public KeyDB Disc Submissions
I was able to successfully rip this release. Here is how it layed out for me: https://thediscdb.com/Movie/wargames-1983
