Cuddy2977
Posts: 59 Joined: Tue Jun 09, 2015 5:42 pm
Post
by Cuddy2977 » Mon Apr 28, 2025 8:20 pm
MrPenguin wrote: Mon Apr 28, 2025 8:16 pm
Cuddy2977 wrote: Mon Apr 28, 2025 8:11 pm
I take it you mean the one called ‘keydb.cfg - Language English (29218 entries)’?
Yes.
And would you know the path name for that folder? I can’t it, again!
It's where MakeMKV writes its TGZ dump files, and is also visible in MakeMKV's "View/Preferences/General" tab as the "data directory".
OK: that directory is /Users/MyName/Library/MakeMKV
That folder contains no item called ‘keydb.cfg’
Screenshot 2025-04-28 at 21.18.36.png (85.33 KiB) Viewed 24900 times
MrPenguin
Posts: 1943 Joined: Thu Oct 19, 2023 11:31 pm
Post
by MrPenguin » Mon Apr 28, 2025 8:23 pm
Cuddy2977 wrote: Mon Apr 28, 2025 8:20 pm
The idea is that you download KEYDB.cfg, copy it
into that folder, and then restart MakeMKV. This allows MakeMKV to use KEYDB.cfg as a "fall-back" database.
Cuddy2977
Post
by Cuddy2977 » Mon Apr 28, 2025 8:24 pm
OK: I’ll give that a try, now
Cuddy2977
Post
by Cuddy2977 » Mon Apr 28, 2025 8:46 pm
MrPenguin wrote: Mon Apr 28, 2025 8:23 pm
Yep: no dice.
Cuddy2977
Post
by Cuddy2977 » Thu May 01, 2025 7:01 am
Right … I owe several people — who shall remain nameless — a big thank you: as my copy of The Terminator now seems to be copying!
Thanks, everyone … !!!
(Now I know how to do these things? I can submit more dumps, as and when: I’ve learnt something as a result of this, so that’s no bad thing)
