Terminator 4K
Cuddy2977
Re: Terminator 4K
Post by Cuddy2977 »
MrPenguin wrote: Mon Apr 28, 2025 8:16 pm
Cuddy2977 wrote: Mon Apr 28, 2025 8:11 pm I take it you mean the one called ‘keydb.cfg - Language English (29218 entries)’?
Yes.
Cuddy2977 wrote: Mon Apr 28, 2025 8:11 pm And would you know the path name for that folder? I can’t it, again!
It's where MakeMKV writes its TGZ dump files, and is also visible in MakeMKV's "View/Preferences/General" tab as the "data directory".
OK: that directory is /Users/MyName/Library/MakeMKV
That folder contains no item called ‘keydb.cfg’
Screenshot 2025-04-28 at 21.18.36.png (85.33 KiB) Viewed 26866 times
MrPenguin
Re: Terminator 4K
Post by MrPenguin »
Cuddy2977 wrote: Mon Apr 28, 2025 8:20 pm That folder contains no item called ‘keydb.cfg’
The idea is that you download KEYDB.cfg, copy it into that folder, and then restart MakeMKV. This allows MakeMKV to use KEYDB.cfg as a "fall-back" database.
Cuddy2977
Re: Terminator 4K
Post by Cuddy2977 »
OK: I’ll give that a try, now
Cuddy2977
Re: Terminator 4K
Post by Cuddy2977 »
MrPenguin wrote: Mon Apr 28, 2025 8:23 pm
Yep: no dice.
Cuddy2977
Re: Terminator 4K
Post by Cuddy2977 »
Right … I owe several people — who shall remain nameless — a big thank you: as my copy of The Terminator now seems to be copying!
Thanks, everyone … !!!
(Now I know how to do these things? I can submit more dumps, as and when: I’ve learnt something as a result of this, so that’s no bad thing)
