Dump Submitted Wargames
Cerina
#1 Post by Cerina » Fri Apr 25, 2025 5:33 pm
MKB20_v77_WARGAMES_E5EE submitted.
MrPenguin
Re: Dump Submitted Wargames
#2 Post by MrPenguin » Sun Apr 27, 2025 6:23 pm
Cerina wrote: Fri Apr 25, 2025 5:33 pm MKB20_v77_WARGAMES_E5EE submitted.
Failing that, could you also make your TGZ dump file available here please, either as an attachment or by providing a download link? Then The Powers That KEYDB could examine it, and possibly even add your disk to KEYDB.
miket
#3 Post by miket » Mon Apr 28, 2025 6:53 pm
Here is the dump file. Hope it helps.
miket
#4 Post by miket » Mon Apr 28, 2025 7:24 pm
Here is a Link to the dumpfile MKB20_v77_WARGAMES_E5EE.tgz https://www.mediafire.com/file/dmsvit5m ... E.tgz/file. Hope it helps
MrPenguin
#5 Post by MrPenguin » Mon Apr 28, 2025 10:47 pm
miket wrote: Mon Apr 28, 2025 7:24 pm Here is a Link to the dumpfile MKB20_v77_WARGAMES_E5EE.tgz https://www.mediafire.com/file/dmsvit5m ... E.tgz/file. Hope it helps
Thanks for providing that. I would also recommend examining SamuriHL's KEYDB Helper tool, which helps MakeMKV integrate with the public KEYDB.
keydb_helper
#6 Post by keydb_helper » Tue Apr 29, 2025 1:13 am
miket wrote: Mon Apr 28, 2025 6:53 pm Here is the dump file. Hope it helps.
Thanks for the disc dump. The E5EE variant of Wargames has been added to the public keydb.
Public KeyDB Disc Submissions
lfoust
#7 Post by lfoust » Sat Jul 19, 2025 5:56 pm
I was able to successfully rip this release. Here is how it layed out for me: https://thediscdb.com/Movie/wargames-1983
