Dump submitted - Ensemble Stars!! Starry Symphony -the midnight sun-
Meuille
#1 Post by Meuille » Mon Apr 28, 2025 5:15 am
I cannot copy this BD now:(
I already emailed svq@makemkv.com
I already placed the KEYDB.CFG in my C:\Users\USERNAME\.MakeMKV
I already used KeyDB Helper by SamuriHL
It has 2 disk
I can copy day1 disk but cannot copy day2 disk
Here is makemkv log:
MakeMKV v1.18.1 win(x64-release) started
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?wJOA3wHS0B/Pns...
Saved AACS dump file as C:\Users\MakeMKV/MKB_v82_あんさんぶるスターズ!!_Starry_Symphony_-the_midnight_sun- Day2_5DD8.tgz
Here is KeyDB Helper's Validate log:
14:06:00 - MODE: ValidateDisc
14:06:00 -  DriveLetter  : G
14:06:00 - SettingsFile: >D:\?쒖꽑???먮즺??Program\FindVUK\config\FindVUK.ini<
14:06:00 - Logfile >D:\?쒖꽑???먮즺??Program\FindVUK\log\2025-04-28_FindVUK.txt< Default Loglevel >2<
14:06:00 - Update enabled - check for update
14:06:01 - No update required
14:06:01 - Open Main-KEYDB file: >C:\Users\MyCom\AppData\Roaming\aacs\KEYDB.cfg<
14:06:06 - Open Backup-KEYDB file: >D:\?쒖꽑???먮즺??Program\FindVUK\VUKbackup\KEYDB.cfg<
14:06:06 - Get basic AACS data
14:06:06 - AACS folder on disc is reachable - Validate is possible
14:06:07 - VolumeName         >BDROM<
14:06:07 - DiscId             >7A395E4B64ABD3B9C7D78EED585E431B639C30ED< (2025-03-05)
14:06:07 - DiscType           >BD<
14:06:07 - MKB Revision       >82<
14:06:07 - Disc-BusEncEnabled >0<
14:06:07 - Drve-BusEncCapable >1<
14:06:07 - UnitKeyCount       >1<
14:06:07 -  >>> UnitKeyENC (1) >EFF668A90F488DE4D88AD6741A6E6493<
14:06:07 - No entry for discid >7A395E4B64ABD3B9C7D78EED585E431B639C30ED< available in keydb >C:\Users\AppData\Roaming\aacs\KEYDB.cfg< - no validation possible!
14:06:07 - Eject the disc now from drive >G:\<
14:06:12 - Successfully ejected the media in drive G!
Here is KeyDB Helper's Disc Info log:
Getting disc info...
Validation Data: 6D01FDD46A7C33213359D1C7C1ABF6D3 [FOUND]
Media Key: [NOT FOUND]
Media Key not found!
[(Disc Info)]
[DiscID]: 0x7A395E4B64ABD3B9C7D78EED585E431B639C30ED
[Volume]: BDROM
[Date]: 2025-03-18
[VID]: 0xC41F87CEAD1EC1E7FEB44CE7B30E58B1
[MKB]: 82
[EncKey]: 1-0xEFF668A90F488DE4D88AD6741A6E6493
[KEYDB_STATUS]:
[STATUS]: not found
[DiscType]: BD
Here is my dump file:
Re: Dump submitted - Ensemble Stars!! Starry Symphony -the midnight sun-
#2 Post by SamuriHL » Mon Apr 28, 2025 3:11 pm
You need to read ALL the instructions. Especially the part where I say KeyDB Helper does NOT contain any keys and that you are responsible for adding them to your keydb.cfg BEFORE attempting to decrypt an MKB 82 disc. The instructions are in the post where you downloaded the KeyDB Helper. Then it'll work just fine.
MrPenguin
#3 Post by MrPenguin » Mon Apr 28, 2025 3:17 pm
Meuille wrote: Mon Apr 28, 2025 5:15 am I cannot copy this BD now:(
Since you have provided your TGZ dump file, I suggest trying KeyDB Helper again in a few hours time. And assuming it works, can you also validate the entry please?
Meuille
#4 Post by Meuille » Tue Apr 29, 2025 5:15 am
SamuriHL wrote: Mon Apr 28, 2025 3:11 pm You need to read ALL the instructions. Especially the part where I say KeyDB Helper does NOT contain any keys and that you are responsible for adding them to your keydb.cfg BEFORE attempting to decrypt an MKB 82 disc. The instructions are in the post where you downloaded the KeyDB Helper. Then it'll work just fine.
I know what you say, however I just wanted to say I already used KeyDB Helper but current keydb.cfg doesn't have my disk's key yet. I will read instructions again, thanks
Meuille
#5 Post by Meuille » Tue Apr 29, 2025 9:14 am
MrPenguin wrote: Mon Apr 28, 2025 3:17 pm
It works! I did rip my disk well. Thanks!
rai510
#6 Post by rai510 » Mon May 05, 2025 7:17 am
I don't know if this is the correct place to ask, but are you considering uploading the blu ray on gdrive or any private site? :0
#7 Post by Woodstock » Mon May 05, 2025 3:23 pm
Are you asking if the person is going to upload an image of the disk, which would be illegal?
