Dumps submitted for ZAZ the collection - 3 movies
acornatom
Post by acornatom »
Dumps submitted for The Naked Gun, Airplane! and Top Secret! from ZAZ The Collection in Australia:
MKB20_v77_Airplane!_A750.tgz
MKB20_v77_The_Naked_Gun_-_Remastered_A570.tgz
MKB20_v77_Top_Secret!_17A8.tgz
agentbrowder
Re: Dumps submitted for ZAZ the collection - 3 movies
Post by agentbrowder »
Attaching these so they can be added to the keydb.
I also emailed these to svq@makemkv.com last week.
keydb_helper
Post by keydb_helper »
agentbrowder wrote:
Fri Dec 13, 2024 5:54 am
Thank you for the disc dumps. These titles have been added to the public keydb. If you could provide disc dumps from LG/Asus drives in the future it would be appreciated as support for Pioneer disc dumps is limited.
Public KeyDB Disc Submissions
  • LG/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
agentbrowder
keydb_helper wrote:
Fri Dec 13, 2024 2:48 pm
Thank you. All three discs work now.
gwenter
Post by gwenter »
I just submitted dumps for the US version of the collection:
MKB20_v77_Airplane!_5663.tgz
MKB20_v77_The_Naked_Gun_-_Remastered_AC4B.tgz
MKB20_v77_Top_Secret!_D5BD.tgz
MrPenguin
Post by MrPenguin »
gwenter wrote:
Sun Apr 27, 2025 11:29 pm
gwenter
Post by gwenter »
MrPenguin wrote:
Mon Apr 28, 2025 12:26 am
Yeah, I did pretty much at the same time as when I made my post but didn't have any luck after doing so either. Appreciate the suggestion though!
MrPenguin
Post by MrPenguin »
gwenter wrote:
Mon Apr 28, 2025 12:33 am
At least two of those titles look familiar to me, and so I would definitely expect the latest KEYDB.cfg file to provide at least some help... :?
Can you provide these dumps, either as attachments or as download links please?
gwenter
Post by gwenter »
MrPenguin wrote:
Mon Apr 28, 2025 10:09 am
Sure thing! Attached them to this post.
Edit: I've gone back and deleted the files as they are already in the KEYDB and my issue ended up being firmware version related rather than dumps being needed.
keydb_helper
gwenter wrote:
Mon Apr 28, 2025 11:18 am
Thanks for the dump files. All three discs are already present in the public keydb.
If you'd like to utilise the open alternative to MakeMKV's native UHD database, you can follow my instructions here or use SamuriHL's utility for Windows (Link)
gwenter
Post by gwenter »
Hmm, I had followed the steps in the first link.
I'm on Linux, so I extracted keydb.cfg to the data directory (/home/<My Username>/.MakeMKV/) and renamed it to KEYDB.cfg. I attempted rebooting my whole machine in case MakeMKV wasn't actually restarting when I closed and re-opened the GUI and I'm still hitting issues. Might be user error or something, I'll keep looking into it and update with any findings. I'll also re-download the keydb in case it didn't actually download properly or I somehow got an out of date version of the file or anything.
MrPenguin
Post by MrPenguin »
gwenter wrote:
Mon Apr 28, 2025 2:20 pm
Coying KEYDB.cfg into /home/<username>/.MakeMKV/ should be all you need to do, unless your KEYDB.cfg file cannot be read for some reason? E.g. owned by another user, say root?
Or maybe a typo, such as KEYDB.cgf or KEYBD.cfg instead of KEYDB.cfg?
gwenter
Post by gwenter »
MrPenguin wrote:
Mon Apr 28, 2025 2:24 pm
Not as far as I can tell. It was owned by my regular non-root user, I gave everybody read/write on it just in case but no change. Prior to that I re-downloaded the archive and did a diff and it looks like there were additional films added between my two download times, but none of the ones I'm trying so that shouldn't have made any impact (I did use the new download just in case). The following is the output of me doing an ls -l on the data directory, I saved the diff between the two versions of the keydb to a text file too but figure I won't upload it unless it's asked for as I don't expect it to be of much use:
ls -l ~/.MakeMKV/
total 58776
-rw-rw-rw- 1 main main 57574270 Apr 28  2025  KEYDB.cfg
-rw-rw-rw- 1 main main   123188 Apr 28 07:11 'MKB20_v77_Airplane!_5663.tgz'
-rw-rw-rw- 1 main main   122607 Apr 27 19:31  MKB20_v77_The_Naked_Gun_-_Remastered_AC4B.tgz
-rw-rw-rw- 1 main main   125720 Apr 28 12:41 'MKB20_v77_Top_Secret!_D5BD.tgz'
-rw-rw-rw- 1 main main  2208256 Apr 27 18:45  _private_data.tar
-rw-rw-rw- 1 main main      384 Apr 28 12:39  screen.conf
-rw-rw-rw- 1 main main      456 Apr 27 18:42  settings.conf
-rw-rw-rw- 1 main main      194 Apr 28 07:11  update.conf
MrPenguin
Post by MrPenguin »
gwenter wrote:
Mon Apr 28, 2025 4:54 pm
Silly question, but are you sure that your UHD drive supports LibreDrive? Or that LibreDrive has been successfully enabled? One of your log files is full of suspicious-looking messages like:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
What does MakeMKV's "Info" window say about LibreDrive? Did you flash its firmware yourself, or buy it "pre-flashed" from a reseller? As a rule, a BU40N should be able to support LibreDrive, but maybe not "out of the box".
Without LibreDrive, MakeMKV cannot disable the drive's built-in bus-encryption...
gwenter
Post by gwenter »
MrPenguin wrote:
Mon Apr 28, 2025 7:38 pm
I was also wondering if something got messed up with my firmware somehow, but I don't know how that could have happened. I flashed it myself and had been successful with UHDs previously, but it's been a couple months since I used it. I was looking around to see if I could find anybody with a similar issue where they'd somehow messed it up but couldn't find anything that seemed to match. I did see some people encountering errors due to power issues with USB drives (which mine is), but I've tried a few different USB ports both with the Y-end USB-A cable and the single-end USB-C cable and no luck (I'd been using USB-C previously when it was succeeding).
Pasting my Drive/LibreDrive/Disc info from MakeMKV's Info panel below (minus my drive serial number):
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.03
Serial number: REDACTED
Highest AACS version: 77
Firmware version: 1.03
Disc Information
Label: Top Secret
Timestamp: 2024-09-11 00:48:47
Protection: AACS2.0/C v77
Data capacity: 60.64 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
