Dump Submitted - Dirty Harry
SpaceCowboy87
Post by SpaceCowboy87 »
Hope this is the correct process for this sort of thing, I'm new here
MKB20_v77_Dirty_Harry_C978.tgz
(3.34 MiB) Downloaded 1102 times
MrPenguin
Re: Dump Submitted - Dirty Harry
Post by MrPenguin »
SpaceCowboy87 wrote:
Sat Apr 26, 2025 4:45 pm
You need to email that TGZ dump file to svq@makemkv.com so that The Powers That MakeMKV can add your disk to MakeMKV's "hashed keys" database.
Having said that, also attaching your dump file here potentially allows The Powers That KEYDB to add your disk to the public KEYDB.cfg file too. Have you tried downloading the KEYDB.cfg file, copying it into MakeMVK's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV? This often helps... ;).
SpaceCowboy87
Thanks for the reply, I did update my keydb file first as I saw someone had already submitted regarding dirty harry (but the version was different to mine)
I've also emailed as I saw a thread explaining that to someone after I posted.
So I think I've covered my bases :D
MrPenguin
Post by MrPenguin »
Sun Apr 27, 2025 3:23 pm
But have you checked the KEYDB file again after providing this TGZ dump file?
Post by SamuriHL »
They KeyDB is constantly being updated. This is one of the main reasons I created the KeyDB Helper so that there's an easy way to use FindVUK to synchronize the KeyDB and copy it to the MakeMKV data directory automatically with the press of a button. Using the Disc Info button in KeyDB Helper can also let you know for certain if your disc is in there or not and whether it contains information required to work with MakeMKV.
viewtopic.php?f=12&t=16883&p=166510#p166510
SpaceCowboy87
MrPenguin wrote:
Sun Apr 27, 2025 4:31 pm
I am just about to as I've noticed it has updated since I posted, thanks again for the help -:)
SpaceCowboy87
SamuriHL wrote:
Sun Apr 27, 2025 4:47 pm
I wasn't aware this existed so will take a look at it this week, I really appreciate pointing it out and for all the effort, cheers :)
