UHD FAQ
Re: UHD FAQ
Sorry for all the new versions but it was quite a big internal code change recently. I just posted what should be the last version for quite a while of the KeyDB Helper. All known bugs are squashed. If you find anything let me know. Enjoy!
nicholfd
Re: UHD FAQ
I think your new link is broken. The link in the post points to: forum.makemkv.com/forum/KeyDB%20Helper%201.0.1.4SamuriHL wrote: Sun Apr 27, 2025 12:23 am Sorry for all the new versions but it was quite a big internal code change recently. I just posted what should be the last version for quite a while of the KeyDB Helper. All known bugs are squashed. If you find anything let me know. Enjoy!
For sale 4K UHD Flashed USB drives:
ASUS Slim, Buffalo Slim, LG Slim,
Buffalo 5 1/4", ASUS 5 1/4",
drives@nicholasfamilycentral.com
Re: UHD FAQ
It contains a mediafire link to download the file. Worked fine for me.nicholfd wrote: Sun Apr 27, 2025 4:42 amI think your new link is broken. The link in the post points to: forum.makemkv.com/forum/KeyDB%20Helper%201.0.1.4SamuriHL wrote: Sun Apr 27, 2025 12:23 am Sorry for all the new versions but it was quite a big internal code change recently. I just posted what should be the last version for quite a while of the KeyDB Helper. All known bugs are squashed. If you find anything let me know. Enjoy!
viewtopic.php?p=166510#p166510
nicholfd
Re: UHD FAQ
The link on the page, if you hover over it or click on it points to the URL I listed above - the actual link in the post is broken.MartyMcNuts wrote: Sun Apr 27, 2025 4:52 amIt contains a mediafire link to download the file. Worked fine for me.nicholfd wrote: Sun Apr 27, 2025 4:42 amI think your new link is broken. The link in the post points to: forum.makemkv.com/forum/KeyDB%20Helper%201.0.1.4SamuriHL wrote: Sun Apr 27, 2025 12:23 am Sorry for all the new versions but it was quite a big internal code change recently. I just posted what should be the last version for quite a while of the KeyDB Helper. All known bugs are squashed. If you find anything let me know. Enjoy!
I agree that if you copy/paste the text from the post in a browser, it does download the file, but the link as posted in the message is broken.
Re: UHD FAQ
I didn't click the link. I right clicked and downloaded with my DL manager. Worked fine.nicholfd wrote: Sun Apr 27, 2025 5:09 amThe link on the page, if you hover over it or click on it points to the URL I listed above - the actual link in the post is broken.MartyMcNuts wrote: Sun Apr 27, 2025 4:52 amIt contains a mediafire link to download the file. Worked fine for me.nicholfd wrote: Sun Apr 27, 2025 4:42 am
Re: UHD FAQ
I'll re-paste it later. Looks like it may have screwed up the copy and paste but it should work as mentioned.
jacksans
Re: UHD FAQ
Hi, I'm still fairly new to all this. I have been using an LGBP50BN40 for a while and I stumbled across a Pioneer BDR-S13U-X that said it was UHD. However, after finally getting it working through some issues related to connecting an internal BDR to a laptop, I went through the forums to find it is not supported due to the version being 1.05, my question is in regard of future support potential. Will these drives with the higher versions ever get support to be able to work with mkv or find a work around to flash them. I do know that with current knowledge there is no chance for it to happen right now, but I am hopping there is a possibility for it to work in the future. (note: I cannot return it unfortunately, I could possibly find other ways to use it, just not the way I wanted to at this time)
Re: UHD FAQ
https://forum.makemkv.com/forum/viewtopic.php?p=173153#p173153jacksans wrote: Sun Apr 27, 2025 9:55 pm Hi, I'm still fairly new to all this. I have been using an LGBP50BN40 for a while and I stumbled across a Pioneer BDR-S13U-X that said it was UHD. However, after finally getting it working through some issues related to connecting an internal BDR to a laptop, I went through the forums to find it is not supported due to the version being 1.05, my question is in regard of future support potential. Will these drives with the higher versions ever get support to be able to work with mkv or find a work around to flash them. I do know that with current knowledge there is no chance for it to happen right now, but I am hopping there is a possibility for it to work in the future. (note: I cannot return it unfortunately, I could possibly find other ways to use it, just not the way I wanted to at this time)
The short answer is maybe, but probably not.
shmengie
Re: UHD FAQ
You, sir, (SamuriHL), are a hero. Worked like a champ, on my first attempt, on a Blu-Ray with new AACS encryption. TYTYTY!
Now, how's about some firmware code to make my disc reader handle SACDs?
Re: UHD FAQ
HEH I don't take any credit. My tool simply makes it easier and more convenient for people to use the tools doing the real work. FindVUK deserves a ton of praise. LIBAACS does a lot of heavy lifting. And the person who posted that MKBV82 device key is the real hero. All I did was slap a marginally useful UI around FindVUK and aacskeys with a little homebrew magic of my own. Nonetheless, I am glad it helped you out! That's the whole point of it.shmengie wrote: Tue May 06, 2025 9:31 pm You, sir, (SamuriHL), are a hero. Worked like a champ, on my first attempt, on a Blu-Ray with new AACS encryption. TYTYTY!
Now, how's about some firmware code to make my disc reader handle SACDs?![]()
epletan
Re: UHD FAQ
Hello Mike,
I tried to rip the Titanic 4K UHD Blu-ray with MakeMKV v1.18.1. My drive is a Pioneer BDR-UDD4 with LibreDrive enabled.
MakeMKV generated a .tgz file because it couldn't decrypt the disc.
Here is the attached file: MKB20_77_Titanic_ECB3.tgz
Thanks in advance for your help!
Re: UHD FAQ
You need to email that .tgz file to svq@makemkv.com.epletan wrote: Mon Jun 30, 2025 9:48 am Hello Mike,
MKB20_v77_Titanic_E8C3.tgz
MrPenguin
Re: UHD FAQ
Thanks for providing this dump file
Would you also have access to another UHD drive please? The BDR-UD04 (Verbatim 43888?) doesn't create a TGZ dump file that The Powers That KEYDB can use
epletan
Re: UHD FAQ
Hello,MrPenguin wrote: Mon Jun 30, 2025 9:21 pmThanks for providing this dump file. Can you also provide the AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself.
Would you also have access to another UHD drive please? The BDR-UD04 (Verbatim 43888?) doesn't create a TGZ dump file that The Powers That KEYDB can use.
Thank you for your feedback.
Here is the requested file, missing from the previous .tgz, for the *Titanic 4K* UHD disc with the complete file MKB_RO.inf.
Don't hesitate to contact us if you need any other information.
Thank you for your work!
epletan
Re: UHD FAQ
Here the new file .tgz with AACS/MKB_RO.inf complete.
