Dump submitted - Nezha
ManagedMoTion
#1 Post by ManagedMoTion » Sat Apr 26, 2025 2:40 pm
submitted via email.
Before anyone ask.
Yes i placed the KEYDB.CFG in my C:\Users\USERNAME\.MakeMKV
yes i've tried restarting MakeMKV.
Not sure what's going on.
MKB20_v68_Ne_Zha_UHD_07C3.tgz
MrPenguin
Re: Dump submitted - Nezha
#2 Post by MrPenguin » Sat Apr 26, 2025 7:34 pm
Before anyone ask.
Could you also make your TGZ dump file available here please, either as an attachment or by providing a download link? This might allow The Powers That KEYDB to add your disk to the KEYDB.cfg file, and then copying this file into your C:\Users\USERNAME\.MakeMKV directory (and restarting MakeMKV) might help you :).
MrPenguin
#3 Post by MrPenguin » Sat Apr 26, 2025 10:33 pm
Thanks for providing this TGZ dump file :). Could you also provide a ZIP containing the AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside the TGZ dump file has been truncated to 56 bytes, which means it's unusable :(.
(The MKB_RO.inf file is likely to be big, which means you will need to ZIP-compress it.)
ManagedMoTion
#4 Post by ManagedMoTion » Mon Apr 28, 2025 3:14 am
Here is a zipped version of Nezha. Sorry about the delay, i've also included the MKB_RO file.
keydb_helper
#5 Post by keydb_helper » Mon Apr 28, 2025 7:12 am
Thanks for providing the dump file and full MKB_RO file.
The complete entry for the 07C3 variant of Ne Zha has been added to the public keydb. Update your local keydb.cfg file and MakeMKV will be able to decrypt your disc.
Public KeyDB Disc Submissions
