Dump Submitted Wargames
Cerina
Post by Cerina »
MKB20_v77_WARGAMES_E5EE submitted.
MrPenguin
Re: Dump Submitted Wargames
Post by MrPenguin »
Cerina wrote: Fri Apr 25, 2025 5:33 pm MKB20_v77_WARGAMES_E5EE submitted.
Failing that, could you also make your TGZ dump file available here please, either as an attachment or by providing a download link? Then The Powers That KEYDB could examine it, and possibly even add your disk to KEYDB.
miket
Post by miket »
Here is the dump file. Hope it helps.
miket
Post by miket »
Here is a Link to the dumpfile MKB20_v77_WARGAMES_E5EE.tgz https://www.mediafire.com/file/dmsvit5m ... E.tgz/file. Hope it helps
MrPenguin
Post by MrPenguin »
miket wrote: Mon Apr 28, 2025 7:24 pm Here is a Link to the dumpfile MKB20_v77_WARGAMES_E5EE.tgz https://www.mediafire.com/file/dmsvit5m ... E.tgz/file. Hope it helps
Thanks for providing that. I would also recommend examining SamuriHL's KEYDB Helper tool, which helps MakeMKV integrate with the public KEYDB.
keydb_helper
Post by keydb_helper »
miket wrote: Mon Apr 28, 2025 6:53 pm Here is the dump file. Hope it helps.
Thanks for the disc dump. The E5EE variant of Wargames has been added to the public keydb.
Public KeyDB Disc Submissions
lfoust
Post by lfoust »
I was able to successfully rip this release. Here is how it layed out for me: https://thediscdb.com/Movie/wargames-1983
