Tombstone 4UHD
Jsbulger
Tombstone 4UHD
Post by Jsbulger »
I just got my pre-order disc, and opened it up and popped it into MakeMKV first thing. I'm using an LG BP60NB10. MakemKV is saying it cannot open the disc. Error output below.
MakeMKV v1.17.9 win(x64-release) started
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
Saved AACS dump file as C:\Users\jared/.MakeMKV/MKB20_v77_TOMBSTONE_12E4.tgz
MrPenguin
Re: Tombstone 4UHD
Post by MrPenguin »
Jsbulger wrote: Wed Apr 23, 2025 10:59 pm ISaved AACS dump file as C:\Users\jared/.MakeMKV/MKB20_v77_TOMBSTONE_12E4.tgz
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. C:\Users\jared\.MakeMKV\ in your case) and restarting MakeMKV?
Re: Tombstone 4UHD
Post by SamuriHL »
This should go in the UHD section but regardless you should email that dump to:
svq@makemkv.com
Additionally it's potentially in the KeyDB.cfg file. You can use my tool to sync the keydb to your MakeMKV data directory and then use the disc info button to scan your disc and see if it's supported there.
viewtopic.php?f=12&t=16883&p=166510#p166510
Jsbulger
Re: Tombstone 4UHD
Post by Jsbulger »
My apologies for posting in the wrong section. The tool to update the Key DB did the trick. I have the tool as a permanent on my pc now. There're so many things to learn for doing this. It's sometimes overwhelming trying to go through all the different articles to figure out something. But I'm thankful for the replies and the help. :)
Re: Tombstone 4UHD
Post by SamuriHL »
That's why I wrote the tool...to try to help people and make it easier. Glad it worked!
lfoust
Re: Tombstone 4UHD
Post by lfoust »
I was able to rip my copy and here is how it layed out: https://thediscdb.com/movie/tombstone-1 ... eelbook-4k
