Terminator 4K
Cuddy2977
Terminator 4K
Post by Cuddy2977 » Wed Apr 23, 2025 4:05 pm
Right …
I’m trying to rip a 4K version of The Terminator: on a 2024 Mac mini with a PIONEER BD-RW BDR-UD04 branded as a Verbatim 43888.
The software tells me: “The volume key is unknown for this disc - video can't be decrypted”
Given the recent Fatal Crash situation … ?
I’m concerned … and wondering how on Earth I get around this … ?
I should add that I’ve also tried ripping in my other optical drive: and washing the disc in soapy water.
With no luck.
MKB20_v77_THE_TERMINATOR_1984_A8B9.tgz
Re: Terminator 4K
Post by Coopervid » Wed Apr 23, 2025 4:38 pm
I guess you haven't allowed internet access. UHDs need it.
Cuddy2977
Re: Terminator 4K
Post by Cuddy2977 » Wed Apr 23, 2025 5:49 pm
Coopervid wrote: Wed Apr 23, 2025 4:38 pm I guess you haven't allowed internet access. UHDs need it.
Right … my system’s online …
How do I make sure the software can access what it needs?
Re: Terminator 4K
Post by Coopervid » Wed Apr 23, 2025 5:56 pm
Cuddy2977 wrote: Wed Apr 23, 2025 5:49 pm
View Preferences General. Check "Enable Internet Access".
Re: Terminator 4K
Post by dcoke22 » Wed Apr 23, 2025 6:14 pm
Read the Hashed Keys section of the UHD FAQ.
Cuddy2977
Re: Terminator 4K
Post by Cuddy2977 » Wed Apr 23, 2025 6:58 pm
Coopervid wrote: Wed Apr 23, 2025 5:56 pm
It already is, Cooper …
Re: Terminator 4K
Post by Coopervid » Wed Apr 23, 2025 7:05 pm
Cuddy2977 wrote: Wed Apr 23, 2025 6:58 pm
Then it's blocked by your firewall / antivirus I suppose.
Cuddy2977
Re: Terminator 4K
Post by Cuddy2977 » Wed Apr 23, 2025 7:32 pm
dcoke22 wrote: Wed Apr 23, 2025 6:14 pm Read the Hashed Keys section of the UHD FAQ.
Cheers, DCoke: I’ve got those sent off.
Cuddy2977
Re: Terminator 4K
Post by Cuddy2977 » Wed Apr 23, 2025 7:33 pm
Coopervid wrote: Wed Apr 23, 2025 7:05 pm
There’s possibly a lot I could say, there …
But it’s not an issue, as far as I can tell
Cuddy2977
Re: Terminator 4K
Post by Cuddy2977 » Mon Apr 28, 2025 7:26 am
Right: I’ve sent off the dumps from my last attempt: on the 23rd April.
And still haven’t heard.
I’ve tried again, today: on the assumption that the relevant update could have been done without my noticing.
I’m retrying the 4k version, again, today, with a similar result to last time: “The volume key is unknown for this disc - video can’t be decrypted”
When should I hear about my first enquiry: does anyone know?
I’m getting a touch anxious …
Re: Terminator 4K
Post by SamuriHL » Mon Apr 28, 2025 11:12 am
Never. You won't be contacted. You simply have to keep trying it periodically and makemkv will grab the latest cached keys. Once your titles are added they'll work. That can take anywhere from a day to several weeks.
MrPenguin
Re: Terminator 4K
Post by MrPenguin » Mon Apr 28, 2025 7:54 pm
Cuddy2977 wrote: Mon Apr 28, 2025 7:26 am I’m getting a touch anxious …
It is possible that the public KEYDB may already contain your key...
Cuddy2977
Re: Terminator 4K
Post by Cuddy2977 » Mon Apr 28, 2025 8:11 pm
MrPenguin wrote: Mon Apr 28, 2025 7:54 pm
I take it you mean the one called ‘keydb.cfg - Language English (29218 entries)’?
And would you know the path name for that folder? I can’t it, again!
Re: Terminator 4K
Post by Coopervid » Mon Apr 28, 2025 8:15 pm
Cuddy2977 wrote: Mon Apr 28, 2025 8:11 pm
Read follow this.
viewtopic.php?f=12&t=16883
MrPenguin
Re: Terminator 4K
Post by MrPenguin » Mon Apr 28, 2025 8:16 pm
Cuddy2977 wrote: Mon Apr 28, 2025 8:11 pm I take it you mean the one called ‘keydb.cfg - Language English (29218 entries)’?
Yes.
Cuddy2977 wrote: Mon Apr 28, 2025 8:11 pm And would you know the path name for that folder? I can’t it, again!
It's where MakeMKV writes its TGZ dump files, and is also visible in MakeMKV's "View/Preferences/General" tab as the "data directory".
