Right …
I’m trying to rip a 4K version of The Terminator: on a 2024 Mac mini with a PIONEER BD-RW BDR-UD04 branded as a Verbatim 43888.
The software tells me: “The volume key is unknown for this disc - video can't be decrypted”
Given the recent Fatal Crash situation … ?
I’m concerned … and wondering how on Earth I get around this … ?
I should add that I’ve also tried ripping in my other optical drive: and washing the disc in soapy water.
With no luck.
Terminator 4K
Cuddy2977
Terminator 4K
Re: Terminator 4K
I guess you haven't allowed internet access. UHDs need it.
Cuddy2977
Re: Terminator 4K
Right … my system’s online …Coopervid wrote: Wed Apr 23, 2025 4:38 pm I guess you haven't allowed internet access. UHDs need it.
How do I make sure the software can access what it needs?
Re: Terminator 4K
Read the Hashed Keys section of the UHD FAQ.
Cuddy2977
Re: Terminator 4K
It already is, Cooper …
Re: Terminator 4K
Then it's blocked by your firewall / antivirus I suppose.Cuddy2977 wrote: Wed Apr 23, 2025 6:58 pmIt already is, Cooper …
Cuddy2977
Cuddy2977
Re: Terminator 4K
There’s possibly a lot I could say, there …
But it’s not an issue, as far as I can tell
Cuddy2977
Re: Terminator 4K
Right: I’ve sent off the dumps from my last attempt: on the 23rd April.
And still haven’t heard.
I’ve tried again, today: on the assumption that the relevant update could have been done without my noticing.
I’m retrying the 4k version, again, today, with a similar result to last time: “The volume key is unknown for this disc - video can’t be decrypted”
When should I hear about my first enquiry: does anyone know?
I’m getting a touch anxious …
Re: Terminator 4K
Never. You won't be contacted. You simply have to keep trying it periodically and makemkv will grab the latest cached keys. Once your titles are added they'll work. That can take anywhere from a day to several weeks.
MrPenguin
Re: Terminator 4K
It is possible that the public KEYDB may already contain your key...
Cuddy2977
Re: Terminator 4K
I take it you mean the one called ‘keydb.cfg - Language English (29218 entries)’?
And would you know the path name for that folder? I can’t it, again!
Re: Terminator 4K
Read follow this.Cuddy2977 wrote: Mon Apr 28, 2025 8:11 pmI take it you mean the one called ‘keydb.cfg - Language English (29218 entries)’?
viewtopic.php?f=12&t=16883
MrPenguin
Re: Terminator 4K
Yes.Cuddy2977 wrote: Mon Apr 28, 2025 8:11 pm I take it you mean the one called ‘keydb.cfg - Language English (29218 entries)’?
It's where MakeMKV writes its TGZ dump files, and is also visible in MakeMKV's "View/Preferences/General" tab as the "data directory".Cuddy2977 wrote: Mon Apr 28, 2025 8:11 pm And would you know the path name for that folder? I can’t it, again!
