Do i need to update my old BH16NS40 drive to play/backup this disc?
gumajatsu
Post by gumajatsu »
Hello everyone.
I have an old LG BH16NS40 drive, manufactured in 2014. It currently has FW1.00. I know it will never be UHD friendly and i don't intend to update it with FW from the guide available here, but i have an issue with a blu-ray i own. Everytime i try to play it, i get displayed a message indicating that my drive needs an update to play the disc correctly. I tried three different backup softwares, including makemkv, but everytime i start the BDMV folder in VLC, i get the same message without the blu-ray actually starting. If i choose to skip menus in VLC the movie starts, but obviously i can not access the menu this way.
Is this an issue with the disc, do i need to update my drives FW or do i actually need a newer drive? I'm lost...
Greetings gumajatsu
Re: Do i need to update my old BH16NS40 drive to play/backup this disc?
Does the problematic disc have AACS v82 encryption? If so, eventually MakeMKV will support it.
If you got another drive that supported LibreDrive, you could play it now.
MrPenguin
Post by MrPenguin »
gumajatsu wrote:
Wed Apr 16, 2025 12:05 pm
Did MakeMKV create a TGZ dump file for this disk? If so, perhaps post that file here please so that people can examine it?
gumajatsu
Post by gumajatsu »
dcoke22 wrote:
Wed Apr 16, 2025 9:16 pm
The disc has AACS v19 and BD+ v2010.9 protection. Sadly i don't have another drive at the moment.
MrPenguin wrote:
Wed Apr 16, 2025 10:37 pm
Can't find a TGZ dump file in the MAKEMKV folder. I will try to back it up again with "log debug messages" enabled once i'm back from vacation in a few days and post it here.
This is a screenshot of VLC player when i try to start the disc.
MrPenguin
Post by MrPenguin »
gumajatsu wrote:
Thu Apr 17, 2025 12:24 pm
Have you installed the support for BD+? This is libbdplus, the vm files and all of the BD+ tables.
I don't have many disks with BD+, but I have still been able to play them in VLC.
gumajatsu
Post by gumajatsu »
MrPenguin wrote:
Thu Apr 17, 2025 2:02 pm
Yes, it is installed. Other BD+ protected discs play without issue.
MrPenguin
Post by MrPenguin »
gumajatsu wrote:
Thu Apr 17, 2025 2:17 pm
Are there BD+ tables for your particular disk? I still don't know which disk we are talking about here.
gumajatsu
Post by gumajatsu »
Sorry, should have included it in the original post: The A Team
MrPenguin
Post by MrPenguin »
gumajatsu wrote:
Thu Apr 17, 2025 2:58 pm
libbdplus does have some tables for "The A Team", although I cannot tell if they match your particular disk without also knowing your disk's MK and Unit Key. Could you make your disk's AACS/Unit_Key_RO.inf and AACS/MKB_RO.inf files available please? Either as attachments, or by providing a download link?
gumajatsu
Post by gumajatsu »
I will do that as soon as i can, probably on monday. Thanks for looking into it!
gumajatsu
Post by gumajatsu »
See
AACS_A.Team.zip
for the requested files.
I'm wondering... Shouldn't makemkv remove the BD+ protection or does it rely on the tables from libbdplus aswell?
MrPenguin
Post by MrPenguin »
gumajatsu wrote:
Mon Apr 21, 2025 1:15 pm
See AACS_A.Team.zip for the requested files.
AFAICT your disk has both an entry in KEYDB.cfg:
0xE080FD4A6FCB59D7D570A7D2B6B8EAE17D8F20E7 = A_TEAM_F8 (The A-Team) | D | 2010-09-24 | ...
and a BD+ table:
.config/bdplus/convtab/43A4D2779CA340C5707B54BE922DD5EB_A_TEAM_F8.bin
I don't know if MakeMKV can remove the BD+, but I would expect (say) VLC to be able to play this disk directly.
gumajatsu
Post by gumajatsu »
Alright, thanks for checking it out for me!
Seems like i need to watch it without menu then.
