Dump submitted - Violent Night - 4K UHD
brardith
Post by brardith »
Dump file attached to this topic as well.
MrPenguin
Re: Dump submitted - Violent Night - 4K UHD
Post by MrPenguin »
brardith wrote: Mon Apr 14, 2025 1:54 pm Dump file attached to this topic as well.
brardith
Post by brardith »
MrPenguin wrote: Mon Apr 14, 2025 2:13 pm
Yeeeeup, I tried it with the keydb dated for today (04/14/2025). Apologies for not including this in the original post.
MrPenguin
Post by MrPenguin »
brardith wrote: Mon Apr 14, 2025 2:52 pm Yeeeeup, I tried it with the keydb dated for today (04/14/2025). Apologies for not including this in the original post.
OK, but AFAICT your disk ID is 0xC528510317D147DCA9F229449732770214D4786A, and the latest KEYDB.cfg has a matching entry.
brardith
Post by brardith »
MrPenguin wrote: Mon Apr 14, 2025 3:22 pm
Let's troubleshoot my process here since I'm the most likely failure point:
Process should be:
1. unzip keydb.cfg to C:\Users\<username>\.MakeMKV
2. Close MakeMKV (if it wasn't already)
3. Open MakeMKV
4. Attempt to open disc
Yes? That's the process I took. I suppose I can do a full reboot to be sure, but I downloaded a super-fresh copy at 0750 my time (about an hour ago), and couldn't open the disc. I will download an EVEN FRESHER copy, swap em out, and do a full reboot.
brardith
Post by brardith »
I downloaded a copy 4 minutes ago and can confirm it has the disk ID you copied above, so I imagine when I put that one in there it'll work just fine.
MrPenguin
Post by MrPenguin »
brardith wrote: Mon Apr 14, 2025 3:52 pm I downloaded a copy 4 minutes ago and can confirm it has the disk ID you copied above, so I imagine when I put that one in there it'll work just fine.
Yes, I would expect it to... ;)
