Game Of Thrones Season 1 UHD 4k Disc
shishykish
Post by shishykish »
For the above disc, I get the following message. I have flashed the encrypted firmware using the SDF tool. I have the HL-DT-ST BD-RE BP60NB10 drive. The disc works flawlessly on my panasonic udp900 player. They are new discs that have never been used. Is there something I am doing wrong?
MakeMKV v1.18.1 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Kishan/MakeMKV_log.txt
DEBUG: Code 0 at 2g`y)1d*msr{}#Bb:121276424
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
Evaluation version, 29 day(s) out of 30 remaining
Saved AACS dump file as C:\Users\Kishan/.MakeMKV/MKB20_v61_Game_Of_Thrones_Season_1_Disc_1_B9CF.tgz
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213132721
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213131341
My current info is
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIK0EP1BE4826
Firmware date: 2120-05-07 09:35
Highest AACS version: 61
Firmware version: 1.02
Disc Information
Label: GOTUHD_S1_D1_B5
Timestamp: 2018-03-07 12:37:14
Protection: AACS2.0/C v61
Data capacity: 92.39 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MrPenguin
Re: MKB20_v61_Game_Of_Thrones_Season_1_Disc_1_B9CF UHD 4k Disc
Post by MrPenguin »
shishykish wrote: Sun Apr 13, 2025 10:26 am For the above disc, I get the following message. I have flashed the encrypted firmware using the SDF tool. I have the HL-DT-ST BD-RE BP60NB10 drive. The disc works flawlessly on my panasonic udp900 player. They are new discs that have never been used. Is there something I am doing wrong?
You need to email your TGZ dump file (MKB20_v61_Game_Of_Thrones_Season_1_Disc_1_B9CF.tgz) to svq@makemkv.com and then wait for MakeMKV to generate your key.
In the meantime, have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
You could also try uploading your TGZ dump file here so that other people can examine it too... ;)
shishykish
Re: Game Of Thrones Season 1 UHD 4k Disc
Hi, I updated it and it's working ok now! thanks
