Scsi error / Posix error - is the disk bad?
ripthem
Post by ripthem »
I get this with Resident Evil Extinction:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '12282230784'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '12282230784'
This error sounds like a problem with the drive, or does that mean the disk is bad?
MrPenguin
Re: Scsi error / Posix error - is the disk bad?
Post by MrPenguin »
ripthem wrote: Sat Apr 12, 2025 9:17 am This error sounds like a problem with the drive, or does that mean the disk is bad?
Have you tried gently cleaning the disk?
ripthem
Post by ripthem »
Yes, but it did not show any marks or whatever - totally clean.
ripthem
Post by ripthem »
I cleaned again, made sure that no speck is left - but the same, at the same offset.
I also tested another disk, which was OK.
So the disk is bad ....
