Dump Submitted Basic Instinct (Lionsgate)
jarrod2750
#1 Post by jarrod2750 » Sat Apr 12, 2025 11:44 am
Hi - I am submitting a dump file for Basic Instinct (Lionsgate)
I've included the zip file and a link. Thanks
https://www.mediafire.com/file/yyq8rpef ... 6.tgz/file
Re: Dump Submitted Basic Instinct (Lionsgate)
#2 Post by dcoke22 » Sat Apr 12, 2025 12:46 pm
You need to email the dump file to svq@makemkv.com.
UHD FAQ
MrPenguin
#3 Post by MrPenguin » Sat Apr 12, 2025 1:29 pm
But the zip file and link are also greatly appreciated :).
keydb_helper
#4 Post by keydb_helper » Sat Apr 12, 2025 1:37 pm
Thank you for providing a suitable disc dump file. As dcoke22 mentioned, it would great if you could email that disc dump file to the MakeMKV team so that native support is eventually possible.
Until such time, the D106 variant of Basic Instinct has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
jarrod2750
#5 Post by jarrod2750 » Sat Apr 12, 2025 3:47 pm
Thank you I did email it too. I included both Lionsgate items in the same email. I appreciate the updates
foucaultm
#6 Post by foucaultm » Wed Apr 23, 2025 7:17 pm
Anyone else running into issues when trying to rip this 4K disc? I'm getting the following message, even after I clean the disc, etc...
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '69615452160'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '69615452160'
Failed to save title 17 to file F:/Basic Instinct 4K/Basic Instinct_t17.mkv
P.S. I was able to rip all other files on the UHD disc except for the two movie files. Both ripped all the way to the end, and then multiple lines of the error message above were listed until I got the dreaded result.
#7 Post by dcoke22 » Thu Apr 24, 2025 12:56 am
That error means the drive was unable to correctly read a spot on the disc.
