Hi - I am submitting a dump file for Basic Instinct (Lionsgate)
I've included the zip file and a link. Thanks
https://www.mediafire.com/file/yyq8rpef ... 6.tgz/file
Dump Submitted Basic Instinct (Lionsgate)
Re: Dump Submitted Basic Instinct (Lionsgate)
You need to email the dump file to svq@makemkv.com.jarrod2750 wrote: Sat Apr 12, 2025 11:44 am Hi - I am submitting a dump file for Basic Instinct (Lionsgate)
UHD FAQ
MrPenguin
But the zip file and link are also greatly appreciated
keydb_helper
Thank you for providing a suitable disc dump file. As dcoke22 mentioned, it would great if you could email that disc dump file to the MakeMKV team so that native support is eventually possible.jarrod2750 wrote: Sat Apr 12, 2025 11:44 am Hi - I am submitting a dump file for Basic Instinct (Lionsgate)
Until such time, the D106 variant of Basic Instinct has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
jarrod2750
Thank you I did email it too. I included both Lionsgate items in the same email. I appreciate the updates
foucaultm
Anyone else running into issues when trying to rip this 4K disc? I'm getting the following message, even after I clean the disc, etc...
P.S. I was able to rip all other files on the UHD disc except for the two movie files. Both ripped all the way to the end, and then multiple lines of the error message above were listed until I got the dreaded result.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '69615452160'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '69615452160'
Failed to save title 17 to file F:/Basic Instinct 4K/Basic Instinct_t17.mkv-
