Dump Submitted Basic Instinct (Lionsgate)
jarrod2750
Post by jarrod2750 »
Hi - I am submitting a dump file for Basic Instinct (Lionsgate)
I've included the zip file and a link. Thanks
https://www.mediafire.com/file/yyq8rpef ... 6.tgz/file
Re: Dump Submitted Basic Instinct (Lionsgate)
jarrod2750 wrote: Sat Apr 12, 2025 11:44 am Hi - I am submitting a dump file for Basic Instinct (Lionsgate)
You need to email the dump file to svq@makemkv.com.
UHD FAQ
MrPenguin
Post by MrPenguin »
jarrod2750 wrote: Sat Apr 12, 2025 11:44 am I've included the zip file and a link. Thanks
dcoke22 wrote: Sat Apr 12, 2025 12:46 pm You need to email the dump file to svq@makemkv.com.
But the zip file and link are also greatly appreciated :).
keydb_helper
Post by keydb_helper »
Thank you for providing a suitable disc dump file. As dcoke22 mentioned, it would great if you could email that disc dump file to the MakeMKV team so that native support is eventually possible.
Until such time, the D106 variant of Basic Instinct has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
jarrod2750
Thank you I did email it too. I included both Lionsgate items in the same email. I appreciate the updates
foucaultm
Post by foucaultm »
Anyone else running into issues when trying to rip this 4K disc? I'm getting the following message, even after I clean the disc, etc...
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '69615452160'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '69615452160'
Failed to save title 17 to file F:/Basic Instinct 4K/Basic Instinct_t17.mkv
P.S. I was able to rip all other files on the UHD disc except for the two movie files. Both ripped all the way to the end, and then multiple lines of the error message above were listed until I got the dreaded result.
That error means the drive was unable to correctly read a spot on the disc.
