Scsi error / Posix error - is the disk bad?
ripthem
#1 Post by ripthem » Sat Apr 12, 2025 9:17 am
I get this with Resident Evil Extinction:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '12282230784'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '12282230784'
This error sounds like a problem with the drive, or does that mean the disk is bad?
MrPenguin
Re: Scsi error / Posix error - is the disk bad?
#2 Post by MrPenguin » Sat Apr 12, 2025 10:24 am
ripthem wrote: Sat Apr 12, 2025 9:17 am This error sounds like a problem with the drive, or does that mean the disk is bad?
Have you tried gently cleaning the disk?
ripthem
#3 Post by ripthem » Sat Apr 12, 2025 4:36 pm
Yes, but it did not show any marks or whatever - totally clean.
ripthem
#4 Post by ripthem » Sat Apr 12, 2025 5:17 pm
I cleaned again, made sure that no speck is left - but the same, at the same offset.
I also tested another disk, which was OK.
So the disk is bad ....
