AACS 2.1 support
keydb_helper
Re: AACS 2.1 support
#151 Post by keydb_helper » Fri Jan 17, 2025 7:06 am
roopdoge wrote:
Fri Jan 17, 2025 1:07 am
Here is the dump file.
Sorry, what do you mean by disk info?
Thanks for providing the disc dump.
Your disc does not utilise AACS 2.1, it is standard AACS 2.0.
Public KeyDB Disc Submissions
roopdoge
#152 Post by roopdoge » Fri Jan 17, 2025 3:00 pm
Thank you for clarifying. Must have looked too quickly!
#153 Post by Billycar11 » Sat Jan 18, 2025 10:09 pm
The right side of make mkv just copy paste the text under disc info
Attachments don't work on the forum
bitjunkie
#154 Post by bitjunkie » Fri Mar 28, 2025 3:28 pm
Disk-Informationen
Label: Heretic
Zeitstempel: 2025-01-19 22:09:17
Schutz: AACS2.0/C v77
Datenkapazität: 60.51 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 2
Markierungen der Bus-Verschlüsselung: 80
MKB20_v77_Heretic_ADF4.tgz
(3.29 MiB) Downloaded 2203 times
#155 Post by dcoke22 » Fri Mar 28, 2025 3:36 pm
Disk-Informationen
Label: Heretic
Anzahl der Layer: 2
Please email the dump file to svq@makemkv.com.
Read more in the hashed keys section of the UHD FAQ.
MrPenguin
#156 Post by MrPenguin » Fri Mar 28, 2025 3:43 pm
Disk-Informationen
Label: Heretic
This dump file has nothing to do with AACS v2.1.
Have you tried downloading the latest KEYDB.cfg, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
chris996
#157 Post by chris996 » Thu Apr 10, 2025 2:02 pm
There is only one UHD movie (Mission Impossible II) from my collection
that has not been decoded and I do not want to give up :)
There is no hash key for this UHD movie in the KEYDB.cfg file.
Can you create one for me?
Disc Information
Label: MISSION IMPOSSIBLE II
Timestamp: 2018-08-23 12:52:26
Protection: AACS2.0/C v65
Data capacity: 58.71 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
BTW. Where is the dump file on the hard disk?
#158 Post by d00zah » Thu Apr 10, 2025 2:21 pm
Disc Information
Number of layers: 2
IF Windows, try looking in the default location... %UserProfile%\.MakeMKV
MakeMKV will report the location of the dump when it generates it.
chris996
#159 Post by chris996 » Thu Apr 10, 2025 5:51 pm
Maybe a stupid question, but where to send a dump file from MakeMKV?
MakeMKV created two files. And where to send AACS directory from UHD movie?
If I can send them by email, that would be great.
#160 Post by dcoke22 » Thu Apr 10, 2025 9:19 pm
There's the UHD FAQ which answers lots of questions.
chris996
#161 Post by chris996 » Fri Apr 11, 2025 8:47 pm
OK, I send a dump file via email - movie Mission Impossible II UHD.
keydb_helper
#162 Post by keydb_helper » Fri Jun 27, 2025 5:38 am
The upcoming release of Fury utilises AACS 2.0 instead of AACS 2.1. I think it is the second or third title to drop AACS 2.1 when re-issued.
#163 Post by SamuriHL » Fri Jun 27, 2025 9:07 am
It really does seem like they've completely deprecated it. Mike had said it was really expensive for them to create titles using it and that it was done in pairs. Given that all but one title was able to be backed up, it seems the expense wasn't worth it to them. Good. Lol
