Sent via email
.MakeMKV/MKB20_v77_Scanners_UHD_3494.tgz
Scanners UHD Dump Files
MrPenguin
Re: Scanners UHD Dump Files
UHD_Lover
I've downloaded the latest KEYDB.cfg but also can't decrypt the Scanners-UHD. Have sent my dump already (MKB20_v77_Scanners_6BA4.tgz).
MrPenguin
Also making your TGZ dump file available here (either as an attachment or a download link) might help people add your disk to KEYDB.UHD_Lover wrote: Sun Mar 30, 2025 5:28 pm I've downloaded the latest KEYDB.cfg but also can't decrypt the Scanners-UHD. Have sent my dump already (MKB20_v77_Scanners_6BA4.tgz).
MrPenguin
The 3494 variant of "Scanners" has been added to KEYDB.cfg, but I don't believe the 6BA4 one has yet.UHD_Lover wrote: Sun Mar 30, 2025 5:28 pm I've downloaded the latest KEYDB.cfg but also can't decrypt the Scanners-UHD. Have sent my dump already (MKB20_v77_Scanners_6BA4.tgz).
UHD_Lover
Where can I see which disc has been added?
I've attached the 6BA4 to this message, maybe it will helps to add that disc to the keydb.cfg.
keydb_helper
Thanks for providing a suitable disc dump file.UHD_Lover wrote: Sun Apr 13, 2025 11:07 pm Where can I see which disc has been added?
The 6BA4 variant of Scanners has been added to the public keydb.
If you'd like to see whether a particular disc has been added to the public keydb, you can calculate the SHA-1 hash of the discs "Unit_Key_RO.inf" file and search for this hash value in the keydb.cfg file with any text editor.
Public KeyDB Disc Submissions
