Can't rip BD AACS82, MakeMKV Supported: FALSE help (solved!)
TerriblewithIT
Post by TerriblewithIT »
I'm not sure if I'm doing this right, but I've been using MakeMKV for several years, and this is the first time I've been unable to rip a Japanese Blu-ray. I'm using MakeMKV v1.18.1 and downloaded KeyDB_Helper_1.0.0.2.
First, The following is what I see in MakeMKV if I have the disc inserted:
Disc Information
Label: M_MORIARTY_RECOLLECTION_DISC1
Timestamp: 2025-02-28 20:47:36
Protection: AACS v82
Data capacity: 20.35 Gb
Disc type: BD-ROM
Number of layers: 1
The log then states:
MakeMKV v1.18.1 win(x64-release) started
This disc uses newer version of AACS protection. Please let us know about it by visiting(...)
Saved AACS dump file as (...)
Due to how I couldn't open the disc, I tried looking for alternative solutions that would help me deal with the volume key, and it's to my understanding I had to get the most updated KEYDB.cfg file, so I installed the KeyDB_Helper tools.
I presume I ran FindVUK.exe successfully since I saw the following:
02:13:15 - Successfully posted to the OnlineDB! >
Preconditions fulfilled - process upload now
Detected BlurayMetaXML - DiscId >C30F599CF623E6787686F3C0389E7659D03243B3<
Upload written to database!
Upload successfully added as NEW Meta entry!
02:13:15 - Successful upload to OnlineDB
02:13:15 - Eject the disc now from drive >F:\<
02:13:17 - Successfully ejected the media in drive F!
After running FINDVUK.exe and getting a KEYDB.cfg file, I then ran KeyDB_Helper.exe and clicking the "Disc Info" button the following text was produced:
Getting disc info...
[DiscID]: 0xC30F599CF623E6787686F3C0389E7659D03243B3
[Volume]: M_MORIARTY_RECOLLECTION_DISC1
[Date]: 2025-02-28
[MKB]: 82
[EncKey]: 1-0x17E7837E6954E883AC39B808DC423418
[DiscType]: BD
KEYDB Entry:
[Title]: ミュージカル『憂国のモリアーティ』Recollection DISC1
[Date]: 2025-02-28
[UnitKey]: 1-0xDBB43F72F3287EFE9F714EFBAB77887D
[MKB]: 82
[MakeMKV SUPPORTED]: FALSE
Prior to generating a keydb entry, I've also sent a copy of the dump file to svq@makemkv.com, which I've attached to this message since that's what I believe I'm supposed to do for AACS v82 encrypted Blu-rays that won't rip.
In any case, since I have a message that states "[MakeMKV SUPPORTED]: FALSE" does this mean that there's nothing I can do to rip the Blu-ray?
I'd greatly appreciate someone's advise on what I can do to rip it since I want a softcopy of the disc to play on my laptop (it plays on a normal Blu-ray player just fine).
(Additionally, this disc came as part of a set of two, but oddly enough, I was able to rip the second disc without problems.)
Last edited by TerriblewithIT on Thu Apr 10, 2025 1:51 am, edited 1 time in total.
dedykjp
Re: Can't rip BD AACS82, MakeMKV Supported: FALSE help
Post by dedykjp »
I don't know why Makemkv can't decrypt, but I created my own, private tool and I able to calculate vuk. Check this:
Title: M_MORIARTY_RECOLLECTION_DISC1
DiskId: c30f599cf623e6787686f3c0389e7659d03243b3
Bus encryption enabled: false
RDK: 00000000000000000000000000000000
VID: 1acb1d21c20872fe48bd4e1db1f47e96
MK: d62df37beec8ad49ce5cbee6ba721f53
VUK: 9654af6ee92c1180d79bdc950187a5f3
MrPenguin
Post by MrPenguin »
dedykjp wrote:
Wed Apr 09, 2025 2:38 pm
RDK: 901f4d8ab17f00009057608ab17f0000
There's no point sharing your RDK, and not just because this disk doesn't enable bus encryption. This RDK is specific to both this disk and to your particular drive. Put this exact same disk into a different drive and the RDK will change.
dedykjp
Post by dedykjp »
MrPenguin wrote:
Wed Apr 09, 2025 2:44 pm
I know about it and that's why I changed the RDK to zeros.
https://forum.makemkv.com/forum/viewtopic.php?f=8&t=37527&p=172232#p172232
Mike has said that for a while at least you still have to submit dumps for AACS v82.
TerriblewithIT
dcoke22 wrote:
Wed Apr 09, 2025 10:23 pm
Thank you so much for the response. I honestly wasn't sure if that was all I had to do since I couldn't find anything about "[MakeMKV SUPPORTED]: FALSE".
kuroba
Re: Can't rip BD AACS82, MakeMKV Supported: FALSE help (solved!)
Post by kuroba »
Have you successfully extracted the contents of the morimyu-BD? could you send me a copy?
As an overseas fan,We really need this XD.
kuroba
Post by kuroba »
BTW,when I run findvuk.exe this is what comes up:
ERROR! Cannot find (supported) DVDfab Passkey, DVDfab Mediaplayer or DVDfab!
I didn't even manage to rip any of the morimyu-bd's.
kuroba wrote:
Thu Apr 10, 2025 11:53 am
Do you have one of those DVDFab products installed?
