AACS Dump - Ice Age 4
Janssen
Post by Janssen »
I hope this works.
I could not rip this dics and MakeMKV spit out a TGZ-File:
MKB_v31_Ice_Age_4_1626.tgz
Re: AACS Dump - Ice Age 4
Since you posted this in the blu-ray section, I assume the disc you're trying to rip is a regular blu-ray. If that's the case, there should be no need to submit a dump and download a hashed key. That is only something that's needed for 4K UHDs.
There's probably something else going on in your case if my assumptions above are true.
MrPenguin
Post by MrPenguin »
Janssen wrote: Fri Jan 31, 2025 12:20 pm
That is a standard BluRay, and KEYDB.cfg already contains its keys. So MakeMKV should be able to decrypt your disk if you copy the KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ files) and then restart MakeMKV.
According to KEYDB, this disk also use BD+.
Janssen
Post by Janssen »
Sorry for the inconvenience.
I have been able to rip the disc in the end, strangely the first run game me this AACS Dump? Again sorry.
