Dump Submitted - Mufasa: The Lion King 4K UHD TGZ Key File
FootFungus07
MKB20_v77_MUFASA-_THE_LION_KING_6E0A.tgz
Egle666
Re: Dump Submitted - Mufasa: The Lion King 4K UHD TGZ Key File
Submitted MKB20_v77_MUFASA-_THE_LION_KING_307E.tgz.
ElvenKind
Also submitted MKB20_v77_MUFASA-_THE_LION_KING_307E.
gelsthorpei
Have not submitted my version of the file having already been submitted twice but for the guys maintaining the keydb.cfg file below is a link to the file.
https://drive.google.com/file/d/1Rhd3C3 ... sp=sharing
dfoles
Here's mine
- MKB20_v77_MUFASA-_THE_LION_KING_6E0A.tgz
- (3.35 MiB) Downloaded 417 times
keydb_helper
gelsthorpei wrote: Tue Apr 01, 2025 12:41 pm Have not submitted my version of the file having already been submitted twice but for the guys maintaining the keydb.cfg file below is a link to the file.
Thanks for the disc dump files.
Support for the 307E and 6E0A variants of Mufasa: The Lion King has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
jonasrex
I submitted MKB20_v77_MUFASA-_THE_LION_KING_8E56.tgz.
MrPenguin
Could you also attach your TGZ dump here please? That would help The Powers That KEYDB assist you here.
adventoure
I attached the TGZ dump.
- MKB20_v77_MUFASA-_THE_LION_KING_8E56.tgz
- (3.35 MiB) Downloaded 426 times
MrPenguin
It looks like your TGZ dump was created using a Verbatim 43888 drive, which means that most of its data is unreadable
Out of curiosity MrPenguin, is it just the Verbatim 43888 (and consequently the Pioneer UD04) that have this issue or is it all Pioneer drives?MrPenguin wrote: Sat Apr 05, 2025 1:32 pm It looks like your TGZ dump was created using a Verbatim 43888 drive, which means that most of its data is unreadable. Would you happen to have another UHD drive please?
adventoure
Yeah, that’s right. I just don’t have another drive on hand at the moment.MrPenguin wrote: Sat Apr 05, 2025 1:32 pmIt looks like your TGZ dump was created using a Verbatim 43888 drive, which means that most of its data is unreadable. Would you happen to have another UHD drive please?
jonasrex
Here is my TGZ, hope this helps. It was created with an LG BU40N. I also have a Pioneer XS07TUHD if that's better.
- (3.35 MiB) Downloaded 457 times
MrPenguin
As a rule, all Pioneer drives are less friendly that LG drives. However, the UD04 is particularly unfriendly, even for a Pioneerdcoke22 wrote: Sat Apr 05, 2025 1:39 pm Out of curiosity MrPenguin, is it just the Verbatim 43888 (and consequently the Pioneer UD04) that have this issue or is it all Pioneer drives?
keydb_helper
Thank you providing a suitable disc dump file.jonasrex wrote: Sat Apr 05, 2025 2:35 pm Here is my TGZ, hope this helps. It was created with an LG BU40N. I also have a Pioneer XS07TUHD if that's better.
The 8E56 variant of Mufasa: The Lion King has been added to the public keydb.
