Sonic The Hedgehog 3 Dump Submitted
Ralph P.
Post by Ralph P. »
Greetings,
MKB20_v77_Sonic_The_Hedgehog_3_FF70
I have also shared the file on Google Drive for Keydb.
Regards,
keydb_helper
Re: Sonic The Hedgehog 3 Dump Submitted
Post by keydb_helper »
Ralph P. wrote: Wed Apr 02, 2025 5:24 pm Greetings,
Regards,
The FF70 variant of Sonic The Hedgehog 3 has been added to the public keydb.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
Ralph P.
Post by Ralph P. »
keydb_helper wrote: Thu Apr 03, 2025 4:23 am
Regards,
Greetings,
This title now rips using the latest keydb file. Thank you!
Regards,
Animaleyez
Post by Animaleyez »
I'm new and was wondering how do I get my Sonic 3 UHD to rip. Is there something else I need to download?
GoodConditionSoap
Post by GoodConditionSoap »
I have submitted an additional entry for this movie. File name:
MKB20_v77_Sonic_The_Hedgehog_3_EAE2.tgz
MrPenguin
Post by MrPenguin »
Animaleyez wrote: Wed Apr 16, 2025 4:09 pm I'm new and was wondering how do I get my Sonic 3 UHD to rip. Is there something else I need to download?
Email your TGZ dump file to svq@makemkv.com. You can also post your dump file here for good measure (either as an attachment or by providing a download link), so that other people can try adding your disk to KEYDB.cfg.
JDLemon
Post by JDLemon »
Strange i have the ff70 variant and i am getting the can not download error but have not had this issue in the past. Is there a manual way to download the file?
MrPenguin
Post by MrPenguin »
JDLemon wrote: Wed Apr 16, 2025 10:30 pm Strange i have the ff70 variant and i am getting the can not download error but have not had this issue in the past. Is there a manual way to download the file?
The UHD FAQ may help you with downloading the latest "hashed keys". However, the latest KEYDB.cfg file also contains the keys for the FF70 variant. You could therefore try downloading this file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV.
Animaleyez
MrPenguin wrote: Wed Apr 16, 2025 9:54 pm
Done and done. I'm not familiar with this process so thank you for you patience. So now what do I need to do?
MrPenguin
Post by MrPenguin »
Animaleyez wrote: Thu Apr 17, 2025 4:43 am Done and done. I'm not familiar with this process so thank you for you patience. So now what do I need to do?
Now you've emailed your TGZ dump file to svq@makemkv.com, the next step is just to wait until MakeMKV can decrypt your disk.
What is the full name of your TGZ dump file please? The FF70 variant's key is already in KEYDB.cfg, which means you could decrypt your disk right now by downloading KEYDB.cfg, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV. If you have any other variant then you would need to provide your TGZ dump file here so that The Powers That KEYDB could examine it.
Animaleyez
MrPenguin wrote: Thu Apr 17, 2025 10:23 am
I've sent the dump file to the email address that you gave originally. That was the 1st part. I've uploaded the dump file as well. I was just wanted to verify the exact location I should put the KEYDB.cfg file. Again I appreciate your patience and I'm fairly new to this. Thanks again in advance.
MrPenguin
Post by MrPenguin »
Animaleyez wrote: Thu Apr 17, 2025 12:40 pm I've uploaded the dump file as well. I was just wanted to verify the exact location I should put the KEYDB.cfg file.
Where did you upload your dump file to, please? I cannot see it here... Although it would only be interesting if not the FF70 variant.
Animaleyez
MrPenguin wrote: Thu Apr 17, 2025 1:41 pm
I sent the dump file to the email address you requested me to. My email is animalyez@gmail if that helps. I don't know exactly where I'm supposed to put the KEYDB.cfg. I've attached a screen shot of the sent email. Please let me know how else I can be of assistance to resolve this.
Animaleyez wrote: Thu Apr 17, 2025 4:46 pm
There are two different key mechanisms. One is built into MakeMKV. When a new disc comes out, users submit the MakeMKV generated dump files to svq@makemkv.com and eventually, once the key is generated, MakeMKV will automatically download the key and use it.
The second key mechanism is the public KEYDB.cfg. This is separate from MakeMKV, but they can use the same dumps MakeMKV generates to create keys that get included in a big public database. You have to either attach the dump to a post here or put the file on the internet somewhere and post a download link here so the good folks who contribute to KEYDB.cfg can get your dump and process it into a key that gets included in the big public database.
MakeMKV, in addition to its built-in key mechanism, can also use the public KEYDB.cfg, but you have to set it up manually. You have to download KEYDB.cfg and put it into the right spot for MakeMKV to see it and also use it. And you'll have to occasionally update it manually as well. The upside to KEYDB.cfg is it is often updated with new keys faster than the built-in mechanism that MakeMKV uses by default.
Animaleyez
dcoke22 wrote: Fri Apr 18, 2025 1:17 pm
Thank you for this explanation, however with this explanation I'm still left with the question of how? More so where. I don't know where to put the KEYDB.cfg to complete the process. This is what I'm asking for specifically. I have MakeMKV, I have the KEYDB.cfg. Now the question is where do I put the KEYDB.cfg to complete the process of updating that allows MakeMKV to work with this movie. This is the part that is shrouded in mystery for the novice. I have the components and I don't know how to combine them to finish this project.
