Dump Submitted - Howl's Moving Castle [SOLVED]
Archeantus
#1 Post by Archeantus » Tue Apr 01, 2025 10:46 pm
MKB_v63_Howl's_Moving_Castle_B552
Toad King
Re: Dump Submitted - Howl's Moving Castle
#2 Post by Toad King » Tue Apr 01, 2025 11:50 pm
Standard Blu-rays that aren't v82 don't need dumps submitted. They should just work if you have a LIbreDrive disc drive. Otherwise you'll have to wait for the new version of MakeMKV coming soon.
viewtopic.php?f=8&t=37493
Archeantus
#3 Post by Archeantus » Tue Apr 01, 2025 11:59 pm
My drive says LibreDrive is enabled but it still fails to open the disc using 1.17.9
MrPenguin
#4 Post by MrPenguin » Wed Apr 02, 2025 12:28 am
Archeantus wrote: Tue Apr 01, 2025 11:59 pm My drive says LibreDrive is enabled but it still fails to open the disc using 1.17.9
Maybe upload the TGZ dump file here so that people can examine it? However, you could also try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV. There are already 10 candidate disks in there which could match yours.
Archeantus
Re: Dump Submitted - Howl's Moving Castle [SOLVED]
#5 Post by Archeantus » Wed Apr 02, 2025 2:36 am
I ended up just restarting my computer and it ripped fine afterwards, not sure what was wrong. Thanks for the advice.
