Dump Submitted - Howl's Moving Castle [SOLVED]
Archeantus
MKB_v63_Howl's_Moving_Castle_B552
Toad King
Re: Dump Submitted - Howl's Moving Castle
Standard Blu-rays that aren't v82 don't need dumps submitted. They should just work if you have a LIbreDrive disc drive. Otherwise you'll have to wait for the new version of MakeMKV coming soon.
viewtopic.php?f=8&t=37493
Archeantus
My drive says LibreDrive is enabled but it still fails to open the disc using 1.17.9
MrPenguin
Maybe upload the TGZ dump file here so that people can examine it? However, you could also try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV. There are already 10 candidate disks in there which could match yours.Archeantus wrote: Tue Apr 01, 2025 11:59 pm My drive says LibreDrive is enabled but it still fails to open the disc using 1.17.9
Archeantus
Re: Dump Submitted - Howl's Moving Castle [SOLVED]
I ended up just restarting my computer and it ripped fine afterwards, not sure what was wrong. Thanks for the advice.
