Penguin Series Disc 1 - 3 dump submited
ictbydesign
#1 Post by ictbydesign » Sun Mar 16, 2025 10:41 am
MKB20_v77_The_Penguin_Season_1_Disc_1_D0CE.tgz
MKB20_v77_The_Penguin_Season_1_Disc_2_CB18.tgz
MKB20_v77_The_Penguin_Season_1_Disc_3_A98E.tgz
keydb_helper
Re: Penguin Series Disc 1 - 3 dump submited
#2 Post by keydb_helper » Sun Mar 16, 2025 11:09 pm
The D0CE, CB18, and A98E set of The Penguin have been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
ictbydesign
#3 Post by ictbydesign » Mon Mar 17, 2025 7:14 am
Thank you, sorry i did not have chance to get the other data you asked for.
I will try it later today.
ictbydesign
#4 Post by ictbydesign » Mon Mar 17, 2025 10:47 am
discs are ripping OK now.
Toad King
#5 Post by Toad King » Mon Mar 17, 2025 10:26 pm
Submitted different dumps for my copy:
MKB20_v77_The_Penguin_Season_1_Disc_1_1826
MKB20_v77_The_Penguin_Season_1_Disc_2_A462
MKB20_v77_The_Penguin_Season_1_Disc_3_66BE
KeyDB works in the meantime for them.
#6 Post by SamuriHL » Mon Mar 17, 2025 10:37 pm
I wish mine would ship.
chetk
#7 Post by chetk » Thu Mar 20, 2025 4:34 am
I submitted those two days ago too, but they still aren't working. Did you ever get yours to work? Usually, it works within hours of submission.
Toad King
#8 Post by Toad King » Thu Mar 20, 2025 4:39 am
I just used the KeyDB for now. Works fine with that.
chetk
#9 Post by chetk » Thu Mar 20, 2025 4:45 am
Thanks for the reply, but I'm not sure how to do that. I loaded the KeyDB_Helper.exe downloaded from the link above, but it didn't recognize the disc ID for disc 1. How do I use KeyDB?
Toad King
#10 Post by Toad King » Thu Mar 20, 2025 4:49 am
You have to use the "Synchronize" option to download the up-to-date DB file. Then re-run MakeMKV and it should work.
chetk
#11 Post by chetk » Thu Mar 20, 2025 4:53 am
Nevermind. I got it.
tulsamatthews
#12 Post by tulsamatthews » Tue Apr 01, 2025 2:55 am
Anyone else still having issues with The Penguin 4K? I've manually loaded the key several times over the last couple of weeks and MKV still says the volume key is unknown on all three discs. Same dump as listed above so it should work.
#13 Post by SamuriHL » Tue Apr 01, 2025 3:13 am
The keydb definitely worked for me on all 3 discs without issue.
MrPenguin
#14 Post by MrPenguin » Tue Apr 01, 2025 10:03 am
keydb_helper
#15 Post by keydb_helper » Tue Apr 01, 2025 3:37 pm
If you provide the disc dump files it shouldn't be too tricky to determine whether your particular discs should be supported by the public keydb. If they are currently supported, I'd guess you may have misplaced the keydb file or failed to unzip the downloaded file.
