North By Northwest 4K Dump
glorenzen
#1 Post by glorenzen » Sun Mar 23, 2025 12:10 am
I sent a dump file, North_By_Northwest_CD3C.tgz to svq@makemkv.com a few days ago
MrPenguin
Re: North By Northwest 4K Dump
#2 Post by MrPenguin » Sun Mar 23, 2025 11:56 am
glorenzen wrote: Sun Mar 23, 2025 12:10 am I sent a dump file, North_By_Northwest_CD3C.tgz to svq@makemkv.com a few days ago
TULSATRAVELER
#3 Post by TULSATRAVELER » Tue Mar 25, 2025 7:45 pm
I also sent a North By Northwest CD3C dump file on the 17th of March and still haven't been able to rip the disc yet after 8 days. Have never had any delays more than 48 hour before.
MrPenguin
#4 Post by MrPenguin » Wed Mar 26, 2025 11:27 am
TULSATRAVELER wrote: Tue Mar 25, 2025 7:45 pm I also sent a North By Northwest CD3C dump file on the 17th of March and still haven't been able to rip the disc yet after 8 days. Have never had any delays more than 48 hour before.
If you can upload this TGZ dump file somewhere then someone might be able to add your disk to KEYDB.
barrettk17
#5 Post by barrettk17 » Sun Mar 30, 2025 11:59 pm
Any update with this one? I am having the same issues for this disk.
MrPenguin
#6 Post by MrPenguin » Mon Mar 31, 2025 12:16 am
barrettk17 wrote: Sun Mar 30, 2025 11:59 pm Any update with this one? I am having the same issues for this disk.
If MakeMKV doesn't have this key yet then the same advice with KEYDB.cfg (see above) still applies...
barrettk17
#7 Post by barrettk17 » Mon Mar 31, 2025 12:20 am
I have downloaded KEYDB.cfg with no luck. :(
keydb_helper
#8 Post by keydb_helper » Mon Mar 31, 2025 12:51 am
barrettk17 wrote: Mon Mar 31, 2025 12:20 am I have downloaded KEYDB.cfg with no luck. :(
If you created the disc dump file with an Asus or LG drive, support for your disc can probably be added to the public keydb.
You can upload the disc dump file to a file host (Google Drive, OneDrive, Dropbox etc) and post the link here. You should also zip and upload the 'AACS' folder on your disc as it may be required.
If you can't provide a suitable dump file you'll probably need to continue waiting for native MakeMKV support.
Public KeyDB Disc Submissions
KeyDB Download
barrettk17
#9 Post by barrettk17 » Mon Mar 31, 2025 10:12 pm
https://drive.google.com/file/d/1x3aA1Y ... sp=sharing
Let me know if this works or doesn't!
TULSATRAVELER
#10 Post by TULSATRAVELER » Tue Apr 01, 2025 10:10 pm
the key is working today, all is good.
