Dump Submitted - Mufasa: The Lion King 4K UHD TGZ Key File
FootFungus07
Post by FootFungus07 »
MKB20_v77_MUFASA-_THE_LION_KING_6E0A.tgz
Egle666
Re: Dump Submitted - Mufasa: The Lion King 4K UHD TGZ Key File
Post by Egle666 »
Submitted MKB20_v77_MUFASA-_THE_LION_KING_307E.tgz.
ElvenKind
Post by ElvenKind »
Also submitted MKB20_v77_MUFASA-_THE_LION_KING_307E.
gelsthorpei
Post by gelsthorpei »
Have not submitted my version of the file having already been submitted twice but for the guys maintaining the keydb.cfg file below is a link to the file.
https://drive.google.com/file/d/1Rhd3C3 ... sp=sharing
dfoles
Post by dfoles »
Here's mine
(3.35 MiB) Downloaded 388 times
keydb_helper
Post by keydb_helper »
gelsthorpei wrote: Tue Apr 01, 2025 12:41 pm Have not submitted my version of the file having already been submitted twice but for the guys maintaining the keydb.cfg file below is a link to the file.
dfoles wrote: Tue Apr 01, 2025 12:48 pmHere's mine
Thanks for the disc dump files.
Support for the 307E and 6E0A variants of Mufasa: The Lion King has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
jonasrex
Post by jonasrex »
I submitted MKB20_v77_MUFASA-_THE_LION_KING_8E56.tgz.
MrPenguin
Post by MrPenguin »
jonasrex wrote: Fri Apr 04, 2025 3:54 pm I submitted MKB20_v77_MUFASA-_THE_LION_KING_8E56.tgz.
Could you also attach your TGZ dump here please? That would help The Powers That KEYDB assist you here.
adventoure
Post by adventoure »
MrPenguin wrote: Fri Apr 04, 2025 11:01 pm
I attached the TGZ dump. :D
(3.35 MiB) Downloaded 405 times
MrPenguin
Post by MrPenguin »
adventoure wrote: Sat Apr 05, 2025 8:28 am I attached the TGZ dump. :D
It looks like your TGZ dump was created using a Verbatim 43888 drive, which means that most of its data is unreadable :(. Would you happen to have another UHD drive please?
MrPenguin wrote: Sat Apr 05, 2025 1:32 pm It looks like your TGZ dump was created using a Verbatim 43888 drive, which means that most of its data is unreadable :(. Would you happen to have another UHD drive please?
Out of curiosity MrPenguin, is it just the Verbatim 43888 (and consequently the Pioneer UD04) that have this issue or is it all Pioneer drives?
adventoure
Yeah, that’s right. I just don’t have another drive on hand at the moment.
jonasrex
Post by jonasrex »
Here is my TGZ, hope this helps. It was created with an LG BU40N. I also have a Pioneer XS07TUHD if that's better.
(3.35 MiB) Downloaded 438 times
MrPenguin
Post by MrPenguin »
dcoke22 wrote: Sat Apr 05, 2025 1:39 pm Out of curiosity MrPenguin, is it just the Verbatim 43888 (and consequently the Pioneer UD04) that have this issue or is it all Pioneer drives?
As a rule, all Pioneer drives are less friendly that LG drives. However, the UD04 is particularly unfriendly, even for a Pioneer :(!
keydb_helper
jonasrex wrote: Sat Apr 05, 2025 2:35 pm Here is my TGZ, hope this helps. It was created with an LG BU40N. I also have a Pioneer XS07TUHD if that's better.
Thank you providing a suitable disc dump file.
The 8E56 variant of Mufasa: The Lion King has been added to the public keydb.
