The Substance 4K UHD dump file (UK release)
RicReeves
Post by RicReeves » Mon Mar 31, 2025 2:55 pm
I have submitted the following dump file for the The Substance 4K UHD from the UK release out today
MKB20_v77_THE_SUBSTANCE_BEC8.tgz
Monkeylord
Re: The Substance 4K UHD dump file (UK release)
Post by Monkeylord » Tue Apr 01, 2025 2:23 pm
Also submitted... same file.
As a reflex, I submit before I remember to check and see if anyone else has submitted the same file.
Oh well.
keydb_helper
Post by keydb_helper » Tue Apr 01, 2025 3:34 pm
Support for the BEC8 variant of The Substance has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
shell
Post by shell » Sat Apr 12, 2025 11:07 am
I just submitted the dump of the 0D8C variant
MKB20_v77_TheSubstance_UHD_0D8C.tgz
MrPenguin
Post by MrPenguin » Sat Apr 12, 2025 1:00 pm
As well as emailing this TGZ dump file to svq@makemkv.com, could you also make it available here please? (Either as an attachment, or by providing a download link?) This would assist The Powers That KEYDB :).
shell
Post by shell » Sun Apr 13, 2025 2:59 pm
Here the file as an attachment
keydb_helper
Post by keydb_helper » Mon Apr 14, 2025 2:27 am
Thanks for providing a suitable disc dump.
The 0D8C variant of The Substance has been added to the public keydb.
katja2500
Re: The Substance 4K UHD dump file (German release)
Post by katja2500 » Thu Apr 17, 2025 12:46 pm
I have submitted the following dump file for the The Substance 4K UHD from the German release out today:
MKB20_v77_THE_SUBSTANCE_99F8.tgz
keydb_helper
Post by keydb_helper » Thu Apr 17, 2025 3:27 pm
The 99F8 variant of The Substance has been added to the public keydb.
mczocker32
Post by mczocker32 » Thu Apr 17, 2025 4:18 pm
My Disc and therefore dump is called "MKB20_v77_MUBIDE006U_99F8" for some reason. Should still be the same key right?
keydb_helper
Post by keydb_helper » Thu Apr 17, 2025 4:57 pm
Yep, the 99F8 variant I referred to corresponds to your disc. The "MUBIDE006U" portion of the disc dump filename corresponds to the volume or filesystem label of the disc.
In your case it seems to correspond to the catalogue number of the German release distributed by Alive: Link (MUBIDE006U should be visible on the spine of your discs case, directly above the UltraHD Blu-ray logo)
