North By Northwest 4K Dump
I sent a dump file, North_By_Northwest_CD3C.tgz to svq@makemkv.com a few days ago
Re: North By Northwest 4K Dump
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?glorenzen wrote: ↑Sun Mar 23, 2025 12:10 amI sent a dump file, North_By_Northwest_CD3C.tgz to svq@makemkv.com a few days ago
TULSATRAVELER
I also sent a North By Northwest CD3C dump file on the 17th of March and still haven't been able to rip the disc yet after 8 days. Have never had any delays more than 48 hour before.
If you can upload this TGZ dump file somewhere then someone might be able to add your disk to KEYDB.TULSATRAVELER wrote: ↑Tue Mar 25, 2025 7:45 pmI also sent a North By Northwest CD3C dump file on the 17th of March and still haven't been able to rip the disc yet after 8 days. Have never had any delays more than 48 hour before.
barrettk17
Any update with this one? I am having the same issues for this disk.
If MakeMKV doesn't have this key yet then the same advice with KEYDB.cfg (see above) still applies...barrettk17 wrote: ↑Sun Mar 30, 2025 11:59 pmAny update with this one? I am having the same issues for this disk.
barrettk17
I have downloaded KEYDB.cfg with no luck.
keydb_helper
If you created the disc dump file with an Asus or LG drive, support for your disc can probably be added to the public keydb.
You can upload the disc dump file to a file host (Google Drive, OneDrive, Dropbox etc) and post the link here. You should also zip and upload the 'AACS' folder on your disc as it may be required.
If you can't provide a suitable dump file you'll probably need to continue waiting for native MakeMKV support.
Public KeyDB Disc Submissions
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
barrettk17
TULSATRAVELER
the key is working today, all is good.
