Jackie Brown Dump Submitted
Ralph P.
Post by Ralph P. » Fri Jan 17, 2025 1:06 pm
Greetings,
MKB20_v77_Jackie_Brown_18FA
The file has also been loaded to Google Drive for Keydb.
Regards,
Ralph P.
Re: Jackie Brown Dump Submitted
Post by Ralph P. » Sat Jan 18, 2025 3:08 pm
Greetings,
This title now rips using the latest Keydb file. Thank you!
Regards,
HanSolo551
Post by HanSolo551 » Tue Jan 21, 2025 6:59 pm
Weird this dump isn't working for my Jackie Brown Disc.
MrPenguin
Post by MrPenguin » Tue Jan 21, 2025 8:34 pm
gentile2226
Post by gentile2226 » Sat Mar 29, 2025 2:07 pm
I have submitted MKB20_v77_JACKIE_BROWN_UHD_90FC.tgz which is the British release.
Edit: Downloading the latest KEYDB didn't fix the issue.
keydb_helper
Post by keydb_helper » Sat Mar 29, 2025 2:32 pm
Could you share a link to this disc dump with the forum?
Public KeyDB Disc Submissions
gentile2226
Post by gentile2226 » Sat Mar 29, 2025 6:10 pm
I don't think it'll be helpful to you because I have an unflashed Pioneer drive but here you go: https://www.mediafire.com/file/pci0m1b8 ... C.tgz/file
Post by SamuriHL » Sat Mar 29, 2025 7:13 pm
Sadly I don't think that'll be a helpful image. Is that the only drive you have?
gentile2226
Post by gentile2226 » Sat Mar 29, 2025 7:46 pm
Yes I'm afraid so
