Greetings,
MKB20_v77_Jackie_Brown_18FA
The file has also been loaded to Google Drive for Keydb.
Regards,
Jackie Brown Dump Submitted
Re: Jackie Brown Dump Submitted
Greetings,
This title now rips using the latest Keydb file. Thank you!
Regards,
Regards,
HanSolo551
Weird this dump isn't working for my Jackie Brown Disc.
gentile2226
I have submitted MKB20_v77_JACKIE_BROWN_UHD_90FC.tgz which is the British release.
Edit: Downloading the latest KEYDB didn't fix the issue.
keydb_helper
Could you share a link to this disc dump with the forum?gentile2226 wrote: Sat Mar 29, 2025 2:07 pm I have submitted MKB20_v77_JACKIE_BROWN_UHD_90FC.tgz which is the British release.
Public KeyDB Disc Submissions
gentile2226
I don't think it'll be helpful to you because I have an unflashed Pioneer drive but here you go: https://www.mediafire.com/file/pci0m1b8 ... C.tgz/filekeydb_helper wrote: Sat Mar 29, 2025 2:32 pmCould you share a link to this disc dump with the forum?gentile2226 wrote: Sat Mar 29, 2025 2:07 pm I have submitted MKB20_v77_JACKIE_BROWN_UHD_90FC.tgz which is the British release.
Sadly I don't think that'll be a helpful image. Is that the only drive you have?
gentile2226
Yes I'm afraid soSamuriHL wrote: Sat Mar 29, 2025 7:13 pm Sadly I don't think that'll be a helpful image. Is that the only drive you have?
