Submitted dump for "Choose Me", from Criterion.
sterickson
#1 Post by sterickson » Fri Mar 28, 2025 2:29 pm
Submitted: MKB20_v77_CHOOSE_ME_81BC.tgz
(3.29 MiB) Downloaded 228 times
MrPenguin
Re: Submitted dump for "Choose Me", from Criterion.
#2 Post by MrPenguin » Fri Mar 28, 2025 2:58 pm
sterickson
#3 Post by sterickson » Fri Mar 28, 2025 4:00 pm
Yes. There is an entry for the movie, but it doesn't work for my disc.
#4 Post by SamuriHL » Fri Mar 28, 2025 8:57 pm
The entry for your disc is definitely in there. If you're on windows, try downloading and running my tool. See here:
viewtopic.php?f=12&t=16883&p=166510#p166510
sterickson
#5 Post by sterickson » Fri Apr 04, 2025 5:26 am
I had used the tool to download and update the key file, but it wasn't working. After several attempts at opening the disc, and failing, it finally worked, without any further changes by me. Not sure why I had some failures, but it did sort itself out. Strange.
