Submitted dump for "Choose Me", from Criterion.
sterickson
Submitted: MKB20_v77_CHOOSE_ME_81BC.tgz
MrPenguin
Re: Submitted dump for "Choose Me", from Criterion.
sterickson
Yes. There is an entry for the movie, but it doesn't work for my disc.
The entry for your disc is definitely in there. If you're on windows, try downloading and running my tool. See here:
viewtopic.php?f=12&t=16883&p=166510#p166510
sterickson
I had used the tool to download and update the key file, but it wasn't working. After several attempts at opening the disc, and failing, it finally worked, without any further changes by me. Not sure why I had some failures, but it did sort itself out. Strange.
