AACS v82 Disc help needed
l94212
#1 Post by l94212 » Fri Mar 28, 2025 12:26 pm
I’m reaching out to ask for help—would anyone be able to update the key database? Do I need to provide any files? From what I understand, I should share the dumped .tgz files. I’ve attached them below. If any other files are required, please let me know.
I actually tried these but did not work.
| DK | DEVICE_KEY 0x7C06DEAE7F49B551DAF538C8CF1811C9 | DEVICE_NODE 0x0E20 | KEY_UV 0x00000E23 | KEY_U_MASK_SHIFT 0x02 ; MKBv82-...
Thanks in advance for your help! I really appreciate it.
MKB_v82_BD_VIDEO_C2F2.tgz
(71.13 KiB) Downloaded 287 times
Vamp898
Re: AACS v82 Disc help needed
#2 Post by Vamp898 » Fri Mar 28, 2025 1:28 pm
MrPenguin
#3 Post by MrPenguin » Sat Mar 29, 2025 12:33 am
l94212 wrote: Fri Mar 28, 2025 12:26 pm I’m reaching out to ask for help—would anyone be able to update the key database? Do I need to provide any files? From what I understand, I should share the dumped .tgz files. I’ve attached them below. If any other files are required, please let me know.
AFAIK MakeMKV does not use any "| DK |", "| PK |" or "| HC |" entries in a KEYDB.cfg file.
Toad King
#4 Post by Toad King » Sat Mar 29, 2025 2:50 am
This key has been added to the KeyDB. If you download the latest version (I recommend using the tool in this post then it should work.
l94212
#5 Post by l94212 » Sat Mar 29, 2025 8:54 am
MrPenguin wrote: Sat Mar 29, 2025 12:33 am
Got that. Thanks for your reply!
