Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
Post by Coopervid » Thu Mar 27, 2025 4:02 pm
Litzner wrote: Thu Mar 27, 2025 1:40 pm If I were buying a new drive today, preferably external, what would be the best option for a drive I can safely flash? I was looking at the Asus BW-16D1X-U, but it appear that they have started coming with newer firmware that is preventing flashing? I was also looking at a BP50NB40 that is currently on sale locally.
Your country of residence? Do you prefer a Pioneer or LG? Pioneer is recommended.
Litzner
Post by Litzner » Thu Mar 27, 2025 4:13 pm
Coopervid wrote: Thu Mar 27, 2025 4:02 pm
I am in the US. I would love a Pioneer if I can get one at a decent price, but I am OK with LG or Asus.
Post by Coopervid » Fri Mar 28, 2025 9:40 am
Litzner wrote: Thu Mar 27, 2025 4:13 pm
PM sent.
Litzner
Post by Litzner » Fri Mar 28, 2025 2:26 pm
Coopervid wrote: Fri Mar 28, 2025 9:40 am PM sent.
If it was to me I didn't get anything.
Post by Coopervid » Fri Mar 28, 2025 5:06 pm
Litzner wrote: Fri Mar 28, 2025 2:26 pm
Read your PM now. Something went wrong yesterday.
GlossedOver
Post by GlossedOver » Sat Mar 29, 2025 12:07 am
Made the mistake of purchasing the BRD-XD08UMB with revision 1.02 and I'm returning. I only have a laptop with USB C, any other drives, doesn't necessarily have to be a slim drive, that can do UHD?
asmcom
Post by asmcom » Sat Mar 29, 2025 9:14 am
GlossedOver wrote: Sat Mar 29, 2025 12:07 am Made the mistake of purchasing the BRD-XD08UMB with revision 1.02 and I'm returning. I only have a laptop with USB C, any other drives, doesn't necessarily have to be a slim drive, that can do UHD?
We can supply BDR-XD08EMB-S on firmware 1-01.
https://shop.uhdfriendlydrives.co.uk/pr ... -variation
If you are on the US, try Billycarr first
Kind Regards
Clare
UHD Friendly Drive Team
NEKNIM
Post by NEKNIM » Sun Mar 30, 2025 5:02 pm
asmcom wrote: Sat Mar 29, 2025 9:14 am
Kind Regards
Clare
On the listing, it says the firmware is 1-02 in the description. Is that a misprint?
asmcom
Post by asmcom » Sun Mar 30, 2025 6:45 pm
NEKNIM wrote: Sun Mar 30, 2025 5:02 pm
Kind Regards
Clare
Yes, this is a misprint which we just corrected.
Hayley
jocka06
Post by jocka06 » Sun Mar 30, 2025 8:10 pm
This is my first post and apologise if it's in the wrong place. Looking to flash my Blu-ray drive to allow it to read 4K discs. I live in the UK and need some guidance whether if it can be done safely. Copied the following info from make MKV
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: ...
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F00
Firmware version: E116/ID71
(Just to clarify - it is am external Blu-ray drive that connects to my computer via USB. The box read ASUS BW-16D1H-U Pro.
Thanks ion advance for the assistance.
mm13579
Post by mm13579 » Tue Apr 01, 2025 2:29 am
LG BU40N Amazon buy and flash it to 1.03mk firmware.
Cost about $100
CharlyTheSneaky
Post by CharlyTheSneaky » Fri Apr 04, 2025 12:28 pm
Hey there,
If I may bump on here, I have the oportunity to buy the LG-BU40N or other pioneer drives as follows : BDR-213-EBK / BDR-212-DBK / BDR-S13-EBK (I haven't seen them in recommanded drives)
They're around the same price where I live (France) and I was curious if Pioneers were more worth it. I've seen that some are too recent and therefore unable to rip properly.
Thank you to anyone who may provide further guidance,
Charly
Post by dcoke22 » Fri Apr 04, 2025 1:01 pm
CharlyTheSneaky wrote: Fri Apr 04, 2025 12:28 pm Hey there,
Charly
If the Pioneer drives are new, then they will almost assuredly come with firmware that's too new to support LibreDrive and thus they won't be able to rip 4K UHDs.
The easiest way to get a new Pioneer drive with older, compatible firmware is to buy from a seller, Asmcom in the case of Europe.
Coopervid might be able to point you in the direction of a drive that isn't branded as a Pioneer but has a Pioneer drive inside it that could be cross flashed to something compatible with MakeMKV. The tools for cross flashing Pioneer drives are not publicly available however.
CharlyTheSneaky
Post by CharlyTheSneaky » Fri Apr 04, 2025 1:45 pm
dcoke22 wrote: Fri Apr 04, 2025 1:01 pm
I was mainly saying that *people* said the drives were "too new" if I buy from Amazon there is no way of knowing if it will be ripable?
Are ALL Pioneer drives (still) affected by this Feb 23 driver updates? Are there any none affected?
dcoke22 wrote: Fri Apr 04, 2025 1:01 pm The easiest way to get a new Pioneer drive with older, compatible firmware is to buy from a seller, Asmcom in the case of Europe.
I will look into this thoroughly thank you!
Also one last question, there is no way to know if a drive is ripable unless it's bought from a trusted source or in your hands right?
Thanks for clearing up a few things,
Post by Coopervid » Fri Apr 04, 2025 2:24 pm
Hey there,
Charly
Let me know your country of residence. You will then receive a PM.
