This is the AACS dump for a Japanese Blu-ray disc (MKB version 81).
MakeMKV was unable to decrypt it, so I'm uploading the dump file for support.
Filename: MKB_v81_BD_ROM_8A30.tgz
Region: Japan
Disc Label: LiVE is Smile Always~LANDER~ at TOKYO GARDEN THEATER
Thanks for your support!
- MKB_v81_BD_ROM_8A30.tgz
- (118.79 KiB) Downloaded 196 times
Re: LiVE is Smile Always~LANDER~ at TOKYO GARDEN THEATER
MakeMKV already supports MKBv81, so you should not have any problem with this disk. All you should need do is put this disk into the BluRay drive and allow MakeMKV to read it directly.
