MKB20_v77_Friends_Season_3_Disc_2_4E22
I tested all the other discs before submitting, so there won't be a glut of new posts for each season disc, thankfully.
Dump Submitted: Friends 4K UHD [Region-Free] Season 3 Disc 2
Re: Dump Submitted: Friends 4K UHD [Region-Free] Season 3 Disc 2
No, I did not. I have "connect to the internet" enabled so I was presuming that I was already pulling the latest. I'll try that right now and update.
The "connect to the internet" option allow MakeMKV to download updates to its own "hashed keys" database automatically. The KEYDB is an alternate public database that MakeMKV can fall back on, should the "hashed keys" not yet contain an entry for your disk.
You add your disk to the "hashed keys" database by emailing your TGZ dump file to svq@makemkv.com. However, you might also be able to add your disk to KEYDB (assuming it's not already present) by making your TGZ dump file available here too.
Thank you very much for laying this out for me, I'm sure it was somewhere I could've found and read, so I apologize for making you type it out.
I've sent the dump to the email address listed, I will attach the TGZ here to ensure coverage.
- MKB20_v77_Friends_Season_3_Disc_2_4E22.tgz
- (3.36 MiB) Downloaded 126 times
I can confirm, even with the current version of keydb.cfg in my C:\Users\<username>\.MakeMKV folder, after a restart of the program this disc is still unreadable.
keydb_helper
Your disc was recently added to the public keydb. Download the latest keydb and it should work properly.
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
With the newest version the disc was decryptable, and I'm on my way. Thanks very much for your help!keydb_helper wrote: ↑Wed Mar 26, 2025 2:09 amYour disc was recently added to the public keydb. Download the latest keydb and it should work properly.
