Dump Submitted - Mufasa: The Lion King 4K UHD TGZ Key File
FootFungus07
#1 Post by FootFungus07 » Mon Mar 24, 2025 12:42 pm
MKB20_v77_MUFASA-_THE_LION_KING_6E0A.tgz
Egle666
Re: Dump Submitted - Mufasa: The Lion King 4K UHD TGZ Key File
#2 Post by Egle666 » Mon Mar 24, 2025 2:27 pm
Submitted MKB20_v77_MUFASA-_THE_LION_KING_307E.tgz.
ElvenKind
#3 Post by ElvenKind » Mon Mar 31, 2025 4:18 pm
Also submitted MKB20_v77_MUFASA-_THE_LION_KING_307E.
gelsthorpei
#4 Post by gelsthorpei » Tue Apr 01, 2025 12:41 pm
Have not submitted my version of the file having already been submitted twice but for the guys maintaining the keydb.cfg file below is a link to the file.
https://drive.google.com/file/d/1Rhd3C3 ... sp=sharing
dfoles
#5 Post by dfoles » Tue Apr 01, 2025 12:48 pm
Here's mine
(3.35 MiB) Downloaded 307 times
keydb_helper
#6 Post by keydb_helper » Tue Apr 01, 2025 3:43 pm
Here's mine
Thanks for the disc dump files.
Support for the 307E and 6E0A variants of Mufasa: The Lion King has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
jonasrex
#7 Post by jonasrex » Fri Apr 04, 2025 3:54 pm
I submitted MKB20_v77_MUFASA-_THE_LION_KING_8E56.tgz.
MrPenguin
#8 Post by MrPenguin » Fri Apr 04, 2025 11:01 pm
Could you also attach your TGZ dump here please? That would help The Powers That KEYDB assist you here.
adventoure
#9 Post by adventoure » Sat Apr 05, 2025 8:28 am
I attached the TGZ dump. :D
(3.35 MiB) Downloaded 313 times
MrPenguin
#10 Post by MrPenguin » Sat Apr 05, 2025 1:32 pm
It looks like your TGZ dump was created using a Verbatim 43888 drive, which means that most of its data is unreadable :(. Would you happen to have another UHD drive please?
#11 Post by dcoke22 » Sat Apr 05, 2025 1:39 pm
Out of curiosity MrPenguin, is it just the Verbatim 43888 (and consequently the Pioneer UD04) that have this issue or is it all Pioneer drives?
adventoure
#12 Post by adventoure » Sat Apr 05, 2025 1:55 pm
Yeah, that’s right. I just don’t have another drive on hand at the moment.
jonasrex
#13 Post by jonasrex » Sat Apr 05, 2025 2:35 pm
Here is my TGZ, hope this helps. It was created with an LG BU40N. I also have a Pioneer XS07TUHD if that's better.
(3.35 MiB) Downloaded 354 times
MrPenguin
#14 Post by MrPenguin » Sat Apr 05, 2025 2:39 pm
As a rule, all Pioneer drives are less friendly that LG drives. However, the UD04 is particularly unfriendly, even for a Pioneer :(!
keydb_helper
#15 Post by keydb_helper » Sun Apr 06, 2025 2:23 am
Thank you providing a suitable disc dump file.
The 8E56 variant of Mufasa: The Lion King has been added to the public keydb.
