Dump Submitted - Mufasa: The Lion King 4K UHD TGZ Key File
FootFungus07
MKB20_v77_MUFASA-_THE_LION_KING_6E0A.tgz
Re: Dump Submitted - Mufasa: The Lion King 4K UHD TGZ Key File
Submitted MKB20_v77_MUFASA-_THE_LION_KING_307E.tgz.
Also submitted MKB20_v77_MUFASA-_THE_LION_KING_307E.
gelsthorpei
Have not submitted my version of the file having already been submitted twice but for the guys maintaining the keydb.cfg file below is a link to the file.
https://drive.google.com/file/d/1Rhd3C3 ... sp=sharing
Here's mine
- MKB20_v77_MUFASA-_THE_LION_KING_6E0A.tgz
- (3.35 MiB) Downloaded 222 times
keydb_helper
gelsthorpei wrote: ↑Tue Apr 01, 2025 12:41 pmHave not submitted my version of the file having already been submitted twice but for the guys maintaining the keydb.cfg file below is a link to the file.
Thanks for the disc dump files.
Support for the 307E and 6E0A variants of Mufasa: The Lion King has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
I submitted MKB20_v77_MUFASA-_THE_LION_KING_8E56.tgz.
Could you also attach your TGZ dump here please? That would help The Powers That KEYDB assist you here.
adventoure
I attached the TGZ dump.
- MKB20_v77_MUFASA-_THE_LION_KING_8E56.tgz
- (3.35 MiB) Downloaded 216 times
It looks like your TGZ dump was created using a Verbatim 43888 drive, which means that most of its data is unreadable
Out of curiosity MrPenguin, is it just the Verbatim 43888 (and consequently the Pioneer UD04) that have this issue or is it all Pioneer drives?
adventoure
Here is my TGZ, hope this helps. It was created with an LG BU40N. I also have a Pioneer XS07TUHD if that's better.
- (3.35 MiB) Downloaded 273 times
As a rule, all Pioneer drives are less friendly that LG drives. However, the UD04 is particularly unfriendly, even for a Pioneer
keydb_helper
Thank you providing a suitable disc dump file.
The 8E56 variant of Mufasa: The Lion King has been added to the public keydb.
