LibreDrive for Pioneer drives
Warren16034
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: DCDL005259UC
Firmware date: 2022-12-27
Highest AACS version: 81
Drive platform: Pioneer RS9331
Firmware version: ID05
Disc Information
Label: THE_MANDALORIAN_SEASON_3_D1
Timestamp: 2024-10-14 16:53:55
Protection: AACS2.0/C v77
Data capacity: 83.79 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
New drive its a no go, attached the dump file I think
OS device name: J:
Revision: 1.02
Disc Information
Number of layers: 3
- dump_FW_4FBD1465858FD54452E5.tgz
- (279 Bytes) Downloaded 1651 times
Is it possible to enable LibreDrive with this drive? Thanks.
OS device name: F:
Product: BD-RW BDR-209M
Revision: 1.50
Serial number: **
Firmware date: 2017-12-21
Highest AACS version: 82
Drive platform: Pioneer RS8601
Firmware version: ID20
- dump_FW_87538AAF4014B5C5EB10.tgz
- (277 Bytes) Downloaded 1495 times
yes email me see below for detailstracetace wrote: Sun Mar 23, 2025 9:01 am Is it possible to enable LibreDrive with this drive? Thanks.
Drive Information OS device name: F: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-209M Revision: 1.50 Serial number: ** Firmware date: 2017-12-21 Bus encryption flags: 1B Highest AACS version: 82 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8601 Firmware version: ID20
Hello! I'm new to this forum, so excuse my ignorance. I just got a new Pioneer drive off of Amazon that I can't find mentioned anywhere on this site. Anyone know if this Pioneer BDR-WX01DMU can unlock LibreDrive and rip UHD?
OS device name: /dev/rdisk5
Product: BD-RW BDR-WX1DM
Revision: 1.01
Serial number: ...
Firmware date: 2023-10-27
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: Pioneer RS8801
Firmware version: ID36
I sent this info to the MakeMKV support email, but I'm not sure exactly who gets those email? Thanks for any help!
Revision: 1.01
Serial number: ...
- Screenshot 2025-03-26 at 5.49.26 PM.png (82.47 KiB) Viewed 16576 times
No it cannot. The issue is the firmware is post 11/2022 and is therefore not updatable for libredrive or UHD.bradh1 wrote: Wed Mar 26, 2025 11:44 pm Hello! I'm new to this forum, so excuse my ignorance. I just got a new Pioneer drive off of Amazon that I can't find mentioned anywhere on this site. Anyone know if this Pioneer BDR-WX01DMU can unlock LibreDrive and rip UHD?
Revision: 1.01
Serial number: ...
Gotcha, thank you Marty! I was actually just reading about that a little while ago. I also came across your posts listing UHD friendly drives for sale. Do you ship to the US?
Hello guys
Please can anybody tell me what is the difference or how the drive differs one from another when one drive identifies platform as RS8E20 and other as SAT 8E20 ? That RS vs SAT prefix.
Do anyone know the difference? Thanks!
No difference. The prefix doesn't matter. Some show it as SAT, some as RS.wyzxvnv wrote: Thu Mar 27, 2025 3:18 pm Hello guys
Grenadier_45
I don't suppose UHD ripping can be enabled on this drive?
OS device name: I:
Product: BD-RW BDR-S12
Revision: 1.01
Serial number: AEDL002534WL
Firmware date: 2020-07-21
Highest AACS version: 64
Drive platform: RS8F00
Firmware version: 1.01/ID45
This should work out of the box on firmware 1.01. Just put a disc in, and it should work.Grenadier_45 wrote: Thu Mar 27, 2025 6:35 pm I don't suppose UHD ripping can be enabled on this drive?
Drive Information OS device name: I: Manufacturer: PIONEER Product: BD-RW BDR-S12 Revision: 1.01 Serial number: AEDL002534WL Firmware date: 2020-07-21 Bus encryption flags: 1B Highest AACS version: 64 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.01/ID45 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Clare
UHD Friendly Drive Team
Grenadier_45
Thank you for the rapid reply, and I confess I don't exactly have many UHD discs to test with, but with The Matrix, I get 'no disc' from MakeMKV. If it's my ignorance of needing to do something different, I'm happy to be educated! The disc is recognised by a Verbatim 43888 (BU40 version).asmcom wrote: Thu Mar 27, 2025 7:26 pm
Clare
Hi, is it possible to enable UHD blu ray flashing on:
If so how can this be done?
Manufacturer: ASUS
Product: SBC-06D2X-U
Revision: 1.10
Firmware date: 2017-04-18
Drive platform: Pioneer RS8590
Firmware version: ID22
Check your PM.Grenadier_45 wrote: Thu Mar 27, 2025 6:35 pm I don't suppose UHD ripping can be enabled on this drive?
PM sent.Lynx27 wrote: Fri Mar 28, 2025 11:27 am Hi, is it possible to enable UHD blu ray flashing on:If so how can this be done?Code: Select all
Manufacturer: ASUS Product: SBC-06D2X-U Revision: 1.10 Firmware date: 2017-04-18 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8590 Firmware version: ID22
leovbernardo
Hi! I've read a lot on this and the other thread wrt the PIONEER BDR-XD05 drive, and apparently many users are having success in making it read 4k UHD discs. Here is the drive info of my unit. Could you please assist me as well? Thanks in advance!
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number:
Firmware date: 2017-06-22
Highest AACS version: 76
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Revision: 3.10
Serial number:
