mirto
#2821 Post by mirto » Thu Mar 20, 2025 10:43 am
How to install libredrive using Linux?
All the utilities I have seen are for Windows.
Any instructions on installing libredrive on a supported BH16NS55 drive using Linux?
Mr_Orange
#2822 Post by Mr_Orange » Thu Mar 20, 2025 10:48 am
asmcom wrote: Thu Mar 20, 2025 3:44 am Based on our experience, the Verbatim drive hasn't been the most reliable, with about a 5% failure rate. We wouldn’t recommend this model.
For a dependable option, any of the retail Pioneer drives would be a great choice. The Pioneer BDR-XD07TB/S, in particular, will work perfectly for your needs.
I assume you'll be copying to ISO to preserve all your full menus and extras, then mounting the ISO container with your Zidoo. That sounds like a solid setup!
For your convenience, here's a link to a top-loader drive that’s slightly more expensive than the Verbatim but offers significantly better reliability:
BDR-XD07TS with BDR-XD07TUHD
Feel free to reach out if you have any questions or need further advice!
Kind regards,
Asmcom
UHD Friendly Drives Team"
https://shop.uhdfriendlydrives.co.uk/pr ... r-xd07tuhd
Why would you be promoting Leawo on your site given this: viewtopic.php?f=5&t=1514.
asmcom
#2823 Post by asmcom » Thu Mar 20, 2025 2:07 pm
Mr_Orange wrote: Thu Mar 20, 2025 10:48 am
Kind regards,
Asmcom
We don't sell Leawo software. We do sell MakeMKV licenses. Do you want one?
TomEd90
#2824 Post by TomEd90 » Thu Mar 20, 2025 10:52 pm
Kind regards,
Asmcom
Much appreciated. Yeah, that's is the rough plan! Although the steps I have are for remuxing the 3D and Atmos tracks using mkvtoolnix was for MKV files, unsure if the process is the same using ISO files.
I think in that case I might grab the Pioneer BDR-XD08TB/S/D model for the USB 3.2 and more common USB A/C connectors. Hopefully the newer version will last a little better and have some improvements over the older model.
Could you advise is there still a makemkv user discount available? Or are items just priced as per the website now? Thanks again
asmcom
#2825 Post by asmcom » Fri Mar 21, 2025 12:06 am
TomEd90 wrote: Thu Mar 20, 2025 10:52 pm
Kind regards,
Asmcom
We have done a special price on the bundles and it also displays special offer.
Kind Regards
Asmcom
asmcom
#2826 Post by asmcom » Fri Mar 21, 2025 7:15 pm
prickelpit68 wrote: Thu Mar 20, 2025 9:04 am Hi everybody,
I am new to this board and primarily interested in converting my blurays and 4K discs into 3D with Owl3D.
For ripping my 4K´s to harddisk I bought a Verbatim 43888 on Amazon Germany, but it does not seem to be able to work with makemkv or anydvd.
Makemkv shows "HL-DT-ST" (Hitachi?) and I read through this thread but feel very unsure about how to flash the drive to make it work with makemkv.
Could anybody help me find the fitting software and maybe write me a little instruction of how to flash the drive? Would be very appreciated, so thank you very much in advance for your help.
We heard from verbatim europe that they will be making new drives with Hitachi internals due to Pioneer no longer supplying verbatim. You must have been supplied one of the new models.
Certainly interesting, hopefully it will be a BU40N or BP55 inside. Please send screenshot of information Panel on right hand side when you 1st open MakeMKV
Asmcom
FluffySloth
#2827 Post by FluffySloth » Sun Mar 23, 2025 10:02 pm
The Vantec CB-ST00U3 adapter seems to work with flashing now at least with the LG WH14NS40 drive
#2828 Post by MartyMcNuts » Mon Mar 24, 2025 1:52 am
asmcom wrote: Fri Mar 21, 2025 7:15 pm
Asmcom
The Verbatim 43888 now comes with a BU40N inside. This change happened a couple of months ago. I have a few of these in stock and I have 1 remaining with the Pioneer BDR-UD04 inside.
prickelpit68
#2829 Post by prickelpit68 » Mon Mar 24, 2025 7:26 am
MartyMcNuts wrote: Mon Mar 24, 2025 1:52 am
Asmcom
Can the BU40N be flashed???
#2830 Post by dcoke22 » Mon Mar 24, 2025 11:53 am
prickelpit68 wrote: Mon Mar 24, 2025 7:26 am Can the BU40N be flashed???
Yes. See the first post in this thread for instructions and links to the necessary tools.
VantecSupport
#2831 Post by VantecSupport » Mon Mar 24, 2025 6:22 pm
I just want to clear up some misunderstandings about flashing firmware on any SATA drive (optical or hard drive or SSD).
The right way to flash firmware is to follow the manufacturer's instructions closely so that the firmware can be flashed correctly.
Not all firmware flashing programs are designed the same. It depends on the person who wrote it.
Moreover, engineering that writes Flashing tools is not like writing programs for end-users where there are error traps and you can undo them.
It is either flash or brick (dead).
IF (big IF) the engineer who wrote the Flashing tool ASSUMING that your optical is directly connected to a SATA controller, he can write it at a lower level communication via a unique instruction set to the Optical drive registers via the SATA command to the optical drive directly.
And if you are trying to use the Flashing tool to flash the firmware via a SATA to USB bridge (like a USB enclosure for a SATA device), it will MAY NOT WORK CORRECTLY.
Many times you end up with a brick optical drive.
IF (big IF) the engineer wrote the Flashing tool knowing that your optical could be connected to a SATA controller OR a USB to SATA bridge chipset, he can write it at a higher level communication via standard SATA command to the Optical drive registers, it will work.
I see these issues all the time not just with optical drives, but also HDD, SSD, and discreet devices.
Please Please follow the flashing instructions closely. If the original design is a SATA optical drive, you can easily assume you need to connect to a SATA controller directly to flash it correctly.
Also make sure of your OS compatibility, like some older flashing tools may not work correctly using Windows 11 due to the tighter device security on the drivers of the device.
ALL Flashing firmware does not even let you undo it, it will only brick your drive.
Do it with care.
I am writing to you as a person with 44 years of PC experience, before the IBM PC, before the Apple II, before the Commodore 64, and before the TRS-80. Take my advice.
devnuil
#2832 Post by devnuil » Tue Mar 25, 2025 8:41 am
Can this made compatible with UHD ?
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: ...
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
asmcom
#2833 Post by asmcom » Tue Mar 25, 2025 11:51 am
devnuil wrote: Tue Mar 25, 2025 8:41 am Can this made compatible with UHD ?
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: ...
Please speak to Billycarr or Marty about this, as they can provide you with a flasher if your model is compatible.
Billycarr
viewtopic.php?f=20&t=17831
MartyMcnuts
viewtopic.php?f=20&t=18747
Litzner
#2834 Post by Litzner » Thu Mar 27, 2025 1:40 pm
If I were buying a new drive today, preferably external, what would be the best option for a drive I can safely flash? I was looking at the Asus BW-16D1X-U, but it appear that they have started coming with newer firmware that is preventing flashing? I was also looking at a BP50NB40 that is currently on sale locally.
#2835 Post by Coopervid » Thu Mar 27, 2025 4:02 pm
Litzner wrote: Thu Mar 27, 2025 1:40 pm If I were buying a new drive today, preferably external, what would be the best option for a drive I can safely flash? I was looking at the Asus BW-16D1X-U, but it appear that they have started coming with newer firmware that is preventing flashing? I was also looking at a BP50NB40 that is currently on sale locally.
Your country of residence? Do you prefer a Pioneer or LG? Pioneer is recommended.
