Penguin Series Disc 1 - 3 dump submited
ictbydesign
Post by ictbydesign »
MKB20_v77_The_Penguin_Season_1_Disc_1_D0CE.tgz
MKB20_v77_The_Penguin_Season_1_Disc_2_CB18.tgz
MKB20_v77_The_Penguin_Season_1_Disc_3_A98E.tgz
keydb_helper
Re: Penguin Series Disc 1 - 3 dump submited
Post by keydb_helper »
ictbydesign wrote:
Sun Mar 16, 2025 10:41 am
The D0CE, CB18, and A98E set of The Penguin have been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
  • LG/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
ictbydesign
Thank you, sorry i did not have chance to get the other data you asked for.
I will try it later today.
ictbydesign
discs are ripping OK now.
Toad King
Post by Toad King »
Submitted different dumps for my copy:
MKB20_v77_The_Penguin_Season_1_Disc_1_1826
MKB20_v77_The_Penguin_Season_1_Disc_2_A462
MKB20_v77_The_Penguin_Season_1_Disc_3_66BE
KeyDB works in the meantime for them.
Post by SamuriHL »
I wish mine would ship.
chetk
Post by chetk »
Toad King wrote:
Mon Mar 17, 2025 10:26 pm
I submitted those two days ago too, but they still aren't working. Did you ever get yours to work? Usually, it works within hours of submission.
Toad King
Post by Toad King »
chetk wrote:
Thu Mar 20, 2025 4:34 am
I just used the KeyDB for now. Works fine with that.
chetk
Post by chetk »
Toad King wrote:
Thu Mar 20, 2025 4:39 am
Thanks for the reply, but I'm not sure how to do that. I loaded the KeyDB_Helper.exe downloaded from the link above, but it didn't recognize the disc ID for disc 1. How do I use KeyDB?
Toad King
Post by Toad King »
chetk wrote:
Thu Mar 20, 2025 4:45 am
You have to use the "Synchronize" option to download the up-to-date DB file. Then re-run MakeMKV and it should work.
chetk
Post by chetk »
Nevermind. I got it.
tulsamatthews
Post by tulsamatthews »
Anyone else still having issues with The Penguin 4K? I've manually loaded the key several times over the last couple of weeks and MKV still says the volume key is unknown on all three discs. Same dump as listed above so it should work.
Post by SamuriHL »
The keydb definitely worked for me on all 3 discs without issue.
MrPenguin
Post by MrPenguin »
tulsamatthews wrote:
Tue Apr 01, 2025 2:55 am
keydb_helper
If you provide the disc dump files it shouldn't be too tricky to determine whether your particular discs should be supported by the public keydb. If they are currently supported, I'd guess you may have misplaced the keydb file or failed to unzip the downloaded file.
