Red One 4k UHD
tjparasite
Red One 4k UHD
Post by tjparasite » Tue Mar 04, 2025 11:26 pm
Here is the dump for Red One 4K UHD
MKB20_v77_Red_One_D6A2
File sent via Email.
Thanks for all you do!!!
caseablee
Re: Red One 4k UHD
Post by caseablee » Wed Mar 05, 2025 6:01 pm
FYI, I was able to rip this same disc today using the latest keydb.cfg
Mechanic-B
Re: Red One 4k UHD
Post by Mechanic-B » Wed Mar 19, 2025 4:41 pm
Dump submitted,
MKB20_v77_Red_One_86C8
marticus24
Re: Red One 4k UHD
Post by marticus24 » Sun Jun 08, 2025 7:42 pm
Submitted earlier today, also...
MKB20_v77_Red_One_D6A3
MrPenguin
Re: Red One 4k UHD
Post by MrPenguin » Sun Jun 08, 2025 8:54 pm
marticus24 wrote: Sun Jun 08, 2025 7:42 pm MKB20_v77_Red_One_D6A3
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV? AFAIK the D6A3 dump file is for exactly the same disk as the D6A2 dump file, which KEYDB.cfg apparently already supports.
marticus24
Re: Red One 4k UHD
Post by marticus24 » Sun Jun 08, 2025 10:58 pm
Hey - thanks for the reply. I actually closed/re-opened the desktop app. Once I tried starting another title and had the same issue, figured it wasn't the key. Successfully finished the new title and just started Red One. Wasn't even able to read contents before... so pretty sure it was on my end or the app pulled the latest upon reopening. Either way, seems to be rolling now. Thank you!
